はじめに
The maintaining of a clean fan promotes the smoothly functioning of the computer.
必要な工具と部品
Carefully flip the device over so that the bottom is facing up.
Slide both of the latches to the left.
Now your laptop should have no screws and no keyboard.
You should now be able to open up the base of the laptop. With a bit of force, detach the sides latches of the base by pulling them open carefully.
Your computer should now look like the provided photo, where you can see where the fan is located.
ある他の人がこのガイドを完成しました。
