メインコンテンツにスキップ
HP Compaq nc6400 Screen Replacement
必要な工具と部品
  1. HP Compaq nc6400 Screen Replacement, Battery: 手順 1、 1の画像 1
    • Turn off and unplug laptop.
  2. HP Compaq nc6400 Screen Replacement: 手順 2、 1の画像 1
    • Locate the battery lock below the battery labeled one.
    • Slide the lock all the way to the left to release the left lock of the battery.
  3. HP Compaq nc6400 Screen Replacement: 手順 3、 1の画像 1
    • Locate the lock labeled two at the bottom right corner below the battery.
    • Slide and hold the lock to the left.
  4. HP Compaq nc6400 Screen Replacement: 手順 4、 1の画像 1
    • Once both the battery locks are unlocked, slide the battery out to remove.
  5. HP Compaq nc6400 Screen Replacement, Screen: 手順 5、 1の画像 1
    • Remove the four 1.2mm Philips #1 screws attaching the plastic cover to the monitor.
    • The screws may have a small, black plastic cover that lays flush with the screen. Remove these using a pointed tool such as the spudger or philips head screwdriver by prying them out.
  6. HP Compaq nc6400 Screen Replacement: 手順 6、 1の画像 1
    • Remove the four 1.2 Philips #1 screws attaching the face plate to the body.
  7. HP Compaq nc6400 Screen Replacement: 手順 7、 3の画像 1 HP Compaq nc6400 Screen Replacement: 手順 7、 3の画像 2 HP Compaq nc6400 Screen Replacement: 手順 7、 3の画像 3
    • Pry up the plastic screen cover using a pry tool.
    • Keeping the pry tool under the trim, slide it around the entire screen until the the cover has completely detached from the base.
    • You might need to slide the display clip on the top of the screen in order to fully remove the plastic cover.
  8. HP Compaq nc6400 Screen Replacement: 手順 8、 2の画像 1 HP Compaq nc6400 Screen Replacement: 手順 8、 2の画像 2
    • Remove the two 1.2 Philips #1 screws holding down the sensor board at the bottom of the monitor.
  9. HP Compaq nc6400 Screen Replacement: 手順 9、 1の画像 1
    • Remove the right-most 1.2mm Philips #1 screw on the bottom of the monitor.
  10. HP Compaq nc6400 Screen Replacement: 手順 10、 2の画像 1 HP Compaq nc6400 Screen Replacement: 手順 10、 2の画像 2
    • Without lifting the bottom of the monitor, gently flip the screen and lay it face down on the keyboard.
  11. HP Compaq nc6400 Screen Replacement: 手順 11、 2の画像 1 HP Compaq nc6400 Screen Replacement: 手順 11、 2の画像 2
    • Remove the tape holding down the video cable to the monitor.
    • Gently pull out the video cable from the monitor.
  12. HP Compaq nc6400 Screen Replacement: 手順 12、 2の画像 1 HP Compaq nc6400 Screen Replacement: 手順 12、 2の画像 2
    • Remove the monitor's power cable from the sensor board.
    • This is the cable on the farthest right of the sensor board.
  13. HP Compaq nc6400 Screen Replacement: 手順 13、 2の画像 1 HP Compaq nc6400 Screen Replacement: 手順 13、 2の画像 2
    • Once all cables attaching the casing to the monitor have been disconnected, remove the entire screen from the computer and lay it on a flat surface.
    • Remove the four 1.2 Philips #1 screws attaching the bezel to the right side of the monitor.
    • Attach bezel to replacement screen.
終わりに
4 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Luis Vazquez
メンバー登録日: 09/24/13
401 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 14-6, Forte Fall 2013 Cal Poly, Team 14-6, Forte Fall 2013人のメンバー
CPSU-FORTE-F13S14G6
5 メンバー
5のガイドは作成済み
コメント 1 件
Nicely done. Thanks?
Peter Q. - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 21
今までの合計 5,476
