メインコンテンツにスキップ
HP Compaq nc6400 Keyboard Replacement
必要な工具と部品
  1. HP Compaq nc6400 Keyboard Replacement, Battery: 手順 1、 1の画像 1
    • Turn off and unplug laptop.
  2. HP Compaq nc6400 Keyboard Replacement: 手順 2、 1の画像 1
    • Locate the battery lock below the battery labeled one.
    • Slide the lock all the way to the left to release the left lock of the battery.
  3. HP Compaq nc6400 Keyboard Replacement: 手順 3、 1の画像 1
    • Locate the lock labeled two at the bottom right corner below the battery.
    • Slide and hold the lock to the left.
  4. HP Compaq nc6400 Keyboard Replacement: 手順 4、 1の画像 1
    • Once both the battery locks are unlocked, slide the battery out to remove.
  5. HP Compaq nc6400 Keyboard Replacement, Keyboard: 手順 5、 1の画像 1
    • Locate and remove the 3 screws holding the keyboard in place from underneath the laptop.
  6. HP Compaq nc6400 Keyboard Replacement: 手順 6、 3の画像 1 HP Compaq nc6400 Keyboard Replacement: 手順 6、 3の画像 2 HP Compaq nc6400 Keyboard Replacement: 手順 6、 3の画像 3
    • Locate and remove the four retaining clips from the edge of the keyboard. To remove pry up gently on the outside edge of the plastic clip. Once the clip pops up pull it straight out.
  7. HP Compaq nc6400 Keyboard Replacement: 手順 7、 2の画像 1 HP Compaq nc6400 Keyboard Replacement: 手順 7、 2の画像 2
    • At this point the back of the keyboard should come up a bit. You may need to use a thin tool to pull it up, but in my case I only needed my hands. Once you have the back of the keyboard propped up as shown pull the keyboard gently towards the screen to remove. Be careful not to pull completely out because there are still connectors attached to it.
  8. HP Compaq nc6400 Keyboard Replacement: 手順 8、 2の画像 1 HP Compaq nc6400 Keyboard Replacement: 手順 8、 2の画像 2
    この手順で使用する道具:
    • Now with tweezers or a gentle prying apparatus gently pull the lock on the retaining clip up to release each ribbon cable. It is important to only pull up on the lock and not the entire clip.
  9. HP Compaq nc6400 Keyboard Replacement: 手順 9、 2の画像 1 HP Compaq nc6400 Keyboard Replacement: 手順 9、 2の画像 2
    • At this point the keyboard should be completely detached and ready to be removed. Be sure to take your time installing the ribbon cables as these can be troublesome if not installed properly
終わりに
3 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Andrew Frost
メンバー登録日: 03/12/14
197 ポイント
1ガイドが承認済み
チーム
UMass Dartmouth, Team 5-3, Cichon Spring 2014 UMass Dartmouth, Team 5-3, Cichon Spring 2014人のメンバー
UMASSD-CICHON-S14S5G3
4 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 13
今までの合計 2,751
