メインコンテンツにスキップ
HP Compaq Presario cq62-214nr Motherboard Replacement
必要な工具と部品
  1. HP Compaq Presario cq62-214nr Motherboard Replacement, Keyboard: 手順 1、 2の画像 1 HP Compaq Presario cq62-214nr Motherboard Replacement, Keyboard: 手順 1、 2の画像 2
    • With all the screws removed from the previous guides. Remove the final eight M2.5X5 mm Philips screws on the back of the laptop
  2. HP Compaq Presario cq62-214nr Motherboard Replacement: 手順 2、 2の画像 1 HP Compaq Presario cq62-214nr Motherboard Replacement: 手順 2、 2の画像 2
    • In the battery housing, there are three screws that hold the keyboard on. These screws are located on the side near the front.
    • In the center of the bottom of the computer between the RAM and the wifi antenna is a 4th keyboard screw that also needs to be removed.
  3. HP Compaq Presario cq62-214nr Motherboard Replacement: 手順 3、 3の画像 1 HP Compaq Presario cq62-214nr Motherboard Replacement: 手順 3、 3の画像 2 HP Compaq Presario cq62-214nr Motherboard Replacement: 手順 3、 3の画像 3
    • Open up the front of the laptop. Use a plastic opening tool to carefully pry open the keyboard from the edges.
  4. HP Compaq Presario cq62-214nr Motherboard Replacement: 手順 4、 1の画像 1
    • Remove the keyboard by pulling on it with your hands.
    • There is a ribbon cable that is still connected on the back of the keyboard. Do not pull off the ribbon cable when pulling up the keyboard.
  5. HP Compaq Presario cq62-214nr Motherboard Replacement: 手順 5、 3の画像 1 HP Compaq Presario cq62-214nr Motherboard Replacement: 手順 5、 3の画像 2 HP Compaq Presario cq62-214nr Motherboard Replacement: 手順 5、 3の画像 3
    • Locate the keyboard cable/wire that attaches the keyboard to the laptop .
    • Locate the latch of the wire connector
    • Unlatch the wire connector and gently pull out the wire with your hands
  6. HP Compaq Presario cq62-214nr Motherboard Replacement, Motherboard: 手順 6、 1の画像 1
    • Remove the four M2.5x5 mm Phillips screws from the exposed keyboard cover.
  7. HP Compaq Presario cq62-214nr Motherboard Replacement: 手順 7、 3の画像 1 HP Compaq Presario cq62-214nr Motherboard Replacement: 手順 7、 3の画像 2 HP Compaq Presario cq62-214nr Motherboard Replacement: 手順 7、 3の画像 3
    • Locate the three tab holding down the cover of the Motherboard.
    • Lift the tabs with using either a plastic opening tool or your fingers.
  8. HP Compaq Presario cq62-214nr Motherboard Replacement: 手順 8、 2の画像 1 HP Compaq Presario cq62-214nr Motherboard Replacement: 手順 8、 2の画像 2
    • Using a plastic opening tool to lift the sides of the cover.
  9. HP Compaq Presario cq62-214nr Motherboard Replacement: 手順 9、 3の画像 1 HP Compaq Presario cq62-214nr Motherboard Replacement: 手順 9、 3の画像 2 HP Compaq Presario cq62-214nr Motherboard Replacement: 手順 9、 3の画像 3
    • Use your hands to gently lift the cover off.
  10. HP Compaq Presario cq62-214nr Motherboard Replacement: 手順 10、 3の画像 1 HP Compaq Presario cq62-214nr Motherboard Replacement: 手順 10、 3の画像 2 HP Compaq Presario cq62-214nr Motherboard Replacement: 手順 10、 3の画像 3
    • Locate the four cables securing the Motherboard.
    • Gently pull cables to unsecure them.
  11. HP Compaq Presario cq62-214nr Motherboard Replacement: 手順 11、 3の画像 1 HP Compaq Presario cq62-214nr Motherboard Replacement: 手順 11、 3の画像 2 HP Compaq Presario cq62-214nr Motherboard Replacement: 手順 11、 3の画像 3
    • Remove the three M2.25x5 mm Phillips screws.
  12. HP Compaq Presario cq62-214nr Motherboard Replacement: 手順 12、 3の画像 1 HP Compaq Presario cq62-214nr Motherboard Replacement: 手順 12、 3の画像 2 HP Compaq Presario cq62-214nr Motherboard Replacement: 手順 12、 3の画像 3
    • Unlatch the final cable and gently remove the Motherboard.
終わりに
3 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Roth Marcelin
メンバー登録日: 10/06/16
726 ポイント
6のガイドは作成済み
チーム
USF Tampa, Team 2-6, Sullivan Fall 2016 USF Tampa, Team 2-6, Sullivan Fall 2016人のメンバー
USFT-SULLIVAN-F16S2G6
3 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 20
今までの合計 1,072
