はじめに
This guide will walk you through the process of accessing, removing and replacing the Cooling Fan for a Compaq Presario V5303NR. The process of accessing the fan will need to be done if the user is thoroughly cleaning the cooling fan. Replacement, meanwhile, needs to be done if the fan is damaged or otherwise rendered inoperable.
The fan in the V5303NR is much less accessable than the fans in most modern laptops, making this process relatively difficult to do and with a slight risk of further damaging the components if improperly done.
必要な工具と部品
Turn the laptop bottom-side up.
Push the battery latch to the left position to unlock the battery.
Remove the battery from its socket.
ある他の人がこのガイドを完成しました。
