メインコンテンツにスキップ
HP Compaq Presario V5303NR Cooling Fan Replacement
必要な工具と部品
  1. HP Compaq Presario V5303NR Cooling Fan Replacement, Cooling Fan: 手順 1、 3の画像 1 HP Compaq Presario V5303NR Cooling Fan Replacement, Cooling Fan: 手順 1、 3の画像 2 HP Compaq Presario V5303NR Cooling Fan Replacement, Cooling Fan: 手順 1、 3の画像 3
    • Turn the laptop bottom-side up.
    • Push the battery latch to the left position to unlock the battery.
    • Remove the battery from its socket.
    • Failure to unplug the computer and remove the battery can result in electrical discharges on contact with the computer's components. This can damage the computer or even hurt the user.
  2. HP Compaq Presario V5303NR Cooling Fan Replacement: 手順 2、 2の画像 1 HP Compaq Presario V5303NR Cooling Fan Replacement: 手順 2、 2の画像 2
    • Use the Phillips #0 screwdriver to remove the 3 5mm #0 screws highlighted in the picture.
    • Use the Phillips #0 screwdriver to remove the 2 4mm #0 screws highlighted in the picture.
    • Use the Phippips #0 screwdriver to remove the 10 5mm #0 screws highlighted in the picture.
    • Keep the different types of screws separate from one another. They will only fit into holes created for screws of their size, and thus cannot fit into other screw holes.
  3. HP Compaq Presario V5303NR Cooling Fan Replacement: 手順 3、 2の画像 1 HP Compaq Presario V5303NR Cooling Fan Replacement: 手順 3、 2の画像 2
    • Remove the laptops bottom panel.
  4. HP Compaq Presario V5303NR Cooling Fan Replacement: 手順 4、 2の画像 1 HP Compaq Presario V5303NR Cooling Fan Replacement: 手順 4、 2の画像 2
    • Use the metal spudger to pry open the two metal latches affixing the fan cover to the laptop.
    • Use the Phillips #00 screwdriver to remove the 4mm #00 screw affixing the fan cover to the laptop.
    • A plastic spudger has a decreased risk of damaging the computer and its components, so it would normally be preferred over the metal. However, due to the limited amount of space between the latch and the fan's casing, the plastic one may not fit, as was the case in the photo above.
  5. HP Compaq Presario V5303NR Cooling Fan Replacement: 手順 5、 1の画像 1
    • Remove the fan cover.
  6. HP Compaq Presario V5303NR Cooling Fan Replacement: 手順 6、 3の画像 1 HP Compaq Presario V5303NR Cooling Fan Replacement: 手順 6、 3の画像 2 HP Compaq Presario V5303NR Cooling Fan Replacement: 手順 6、 3の画像 3
    • Carefully unplug the plastic piece at the end of the wire from the motherboard at the highlighted point.
    • Carefully remove said plastic piece from the end of the wire bundle at the end of the wire.
    • Do not lose this plastic piece, as it plugs the fan into the fan's power supply.
    • Be very careful to avoid damaging any of the components listed above. If any of these parts are damaged, the fan, if not the computer as a whole, could be irreparably damaged.
  7. HP Compaq Presario V5303NR Cooling Fan Replacement: 手順 7、 1の画像 1
    • Use the Phillips #00 screwdriver on the three 4mm #00 screws affixing the fan to the laptop.
  8. HP Compaq Presario V5303NR Cooling Fan Replacement: 手順 8、 2の画像 1 HP Compaq Presario V5303NR Cooling Fan Replacement: 手順 8、 2の画像 2
    • Carefully unweave the fan's wire from the two highlighted overhangs holding it in place.
    • The first image shows the white plastic piece still attached to the wire. This was an oversight on the photographers. If you have followed the guide to this point, this piece should already have been removed.
    • Feed the wire and wire bundle through the hole in the fan case.
  9. HP Compaq Presario V5303NR Cooling Fan Replacement: 手順 9、 1の画像 1
    • Remove the cooling fan, alongside its wire, from the fan's casing.
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Chris Obesky
メンバー登録日: 03/16/18
617 ポイント
3のガイドは作成済み
チーム
UMass Dartmouth, Team S4-G3, Covino Spring 2018 UMass Dartmouth, Team S4-G3, Covino Spring 2018人のメンバー
UMASSD-COVINO-S18S4G3
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 447
