メインコンテンツにスキップ
HP Compaq Presario V3000 CD/DVD ROM Replacement
必要な工具と部品
  1. HP Compaq Presario V3000 CD/DVD ROM Replacement, Battery: 手順 1、 1の画像 1
    • Make sure the laptop is powered OFF. Gently turn the laptop over and place it on a flat surface.
    • The battery may be warm or even HOT to the touch.
    • Locate the battery EJECT latch.
  2. HP Compaq Presario V3000 CD/DVD ROM Replacement: 手順 2、 2の画像 1 HP Compaq Presario V3000 CD/DVD ROM Replacement: 手順 2、 2の画像 2
    • Grab the laptop firmly on the side and using your thumb, press the eject latch towards the OUTER edge of the device.
    • The battery will be lifted out of the laptop slightly as you press the latch over as far as it will go.
    • When replacing the battery, you DO NOT need to adjust the latch. Once the battery is replaced, snap it into place and the latch will return to normal.
  3. HP Compaq Presario V3000 CD/DVD ROM Replacement: 手順 3、 2の画像 1 HP Compaq Presario V3000 CD/DVD ROM Replacement: 手順 3、 2の画像 2
    • Pull the battery up and towards you to remove it from the laptop chassis.
    • Once the battery is out, you will be able to check the battery label for the replacement part number.
    • The part number is needed when purchasing a new battery.
  4. HP Compaq Presario V3000 CD/DVD ROM Replacement, CD/DVD ROM: 手順 4、 2の画像 1 HP Compaq Presario V3000 CD/DVD ROM Replacement, CD/DVD ROM: 手順 4、 2の画像 2
    • Locate the CD/DVD ROM drive. In order to recover an important disc from the drive, locate the manual release hole.
    • Insert paper clip or other small diameter object to engage the release mechanism.
    • Apply slow, steady pressure until the drive pops out. The ejection mechanism in the manual release hole is small. Multiple attempts may be needed to eject.
  5. HP Compaq Presario V3000 CD/DVD ROM Replacement: 手順 5、 2の画像 1 HP Compaq Presario V3000 CD/DVD ROM Replacement: 手順 5、 2の画像 2
    • Locate the screw that secure the CD/DVD ROM drive.
    • Use Philips #0 screwdriver to remove the 2.5 x 5.0mm CD/DVD ROM screw.
    • Place the 2.5 x 5.0mm CD/DVD ROM drive screw on the magnetic project mat.
  6. HP Compaq Presario V3000 CD/DVD ROM Replacement: 手順 6、 3の画像 1 HP Compaq Presario V3000 CD/DVD ROM Replacement: 手順 6、 3の画像 2 HP Compaq Presario V3000 CD/DVD ROM Replacement: 手順 6、 3の画像 3
    • Slowly remove the CD/DVD ROM drive from the laptop.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Samuel Lootens
メンバー登録日: 07/25/16
203 ポイント
1ガイドが承認済み
チーム
University of Memphis, Team 1-4, Kim SU 2016 University of Memphis, Team 1-4, Kim SU 2016人のメンバー
UM-KIM-SU16S1G4
3 メンバー
3のガイドは作成済み
コメント 1 件
very helpful. thanks and regards
kayvee1234 - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 14
今までの合計 1,807
