メインコンテンツにスキップ
HP Compaq C700 Fan Replacement
必要な工具と部品
  1. HP Compaq C700 Fan Replacement, Keyboard: 手順 1、 1の画像 1
    • It is advised to work on the device only when it is powered off so as to avoid electrocution risks.
    • Turn off computer by pressing and holding the power button.
  2. HP Compaq C700 Fan Replacement: 手順 2、 3の画像 1 HP Compaq C700 Fan Replacement: 手順 2、 3の画像 2 HP Compaq C700 Fan Replacement: 手順 2、 3の画像 3
    • Locate and unscrew the two screws on the back marked with a small keyboard. These screws hold the keyboard in place.
    • Locate the metal hooks where the keyboard connects to the laptop and use a metal spudger to gently pry up the keyboard.
  3. HP Compaq C700 Fan Replacement: 手順 3、 1の画像 1
    • Gently lift up and remove the keyboard.
  4. HP Compaq C700 Fan Replacement, Fan: 手順 4、 1の画像 1
    • Turn the laptop over so that you see the bottom.
    • Locate the twenty 3 mm Phillips head screws.
    • Unscrew them using the PH0 screwdriver
  5. HP Compaq C700 Fan Replacement: 手順 5、 1の画像 1
    • After unscrewing the 3 mm screws, remove the hard drive covering by lifting upward.
  6. HP Compaq C700 Fan Replacement: 手順 6、 1の画像 1
    • Remove the hard drive by pulling on the plastic tab and lifting upward.
  7. HP Compaq C700 Fan Replacement: 手順 7、 1の画像 1
    • Remove the covering that houses the RAM modules.
  8. HP Compaq C700 Fan Replacement: 手順 8、 1の画像 1
    • Locate and unscrew the two Phillips head 3 mm screws on the wireless card.
  9. HP Compaq C700 Fan Replacement: 手順 9、 1の画像 1
    • Unhook the two wires connecting to the wireless card by gently pulling them out.
  10. HP Compaq C700 Fan Replacement: 手順 10、 1の画像 1
    • Gently lift and pull out the card.
  11. HP Compaq C700 Fan Replacement: 手順 11、 1の画像 1
    この手順で使用する道具:
    • Locate the power button connector wire. (This can be found where the keyboard sits.)
    • Using the tweezers, unhook the wire.
  12. HP Compaq C700 Fan Replacement: 手順 12、 2の画像 1 HP Compaq C700 Fan Replacement: 手順 12、 2の画像 2
    • Press and hold the lock to pop the panel piece above the keyboard and pull up to remove it.
  13. HP Compaq C700 Fan Replacement: 手順 13、 2の画像 1 HP Compaq C700 Fan Replacement: 手順 13、 2の画像 2
    • Unplug the remaining wires using the tweezers.
  14. HP Compaq C700 Fan Replacement: 手順 14、 1の画像 1
    • Gently pull out the three wires.
  15. HP Compaq C700 Fan Replacement: 手順 15、 2の画像 1 HP Compaq C700 Fan Replacement: 手順 15、 2の画像 2
    • Locate the four 3 mm Phillips head screws.
    • Unscrew them using the PH0 screwdriver.
  16. HP Compaq C700 Fan Replacement: 手順 16、 1の画像 1
    • Unhook the display connector wire.
  17. HP Compaq C700 Fan Replacement: 手順 17、 1の画像 1
    • Gently disconnect the display by pulling it upwards.
  18. HP Compaq C700 Fan Replacement: 手順 18、 1の画像 1
    • Locate the disk drive on the side of the device.
    • Remove it by pulling it all the way out.
  19. HP Compaq C700 Fan Replacement: 手順 19、 1の画像 1
    • Use the PH0 screwdriver to remove the two 3 mm Phillips head screws in the disk drive port.
  20. HP Compaq C700 Fan Replacement: 手順 20、 1の画像 1
    • Locate and unplug the touchpad connection using the tweezers.
  21. HP Compaq C700 Fan Replacement: 手順 21、 3の画像 1 HP Compaq C700 Fan Replacement: 手順 21、 3の画像 2 HP Compaq C700 Fan Replacement: 手順 21、 3の画像 3
    • Using the Opening tool, gently pry up the cover and remove it.
  22. HP Compaq C700 Fan Replacement: 手順 22、 1の画像 1
    • Unplug the fan wire connection using the tweezers.
  23. HP Compaq C700 Fan Replacement: 手順 23、 1の画像 1
    • Locate the 3 mm Phillips head screw.
    • Unscrew it using the PH0 screwdriver.
  24. HP Compaq C700 Fan Replacement: 手順 24、 2の画像 1 HP Compaq C700 Fan Replacement: 手順 24、 2の画像 2
    • Using the opening tool, gently pry up and remove the fan.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Taylor Johansen
メンバー登録日: 10/20/16
690 ポイント
5のガイドは作成済み
チーム
UMass Dartmouth, Team 5-6, Martin Fall 2016 UMass Dartmouth, Team 5-6, Martin Fall 2016人のメンバー
UMASSD-MARTIN-F16S5G6
3 メンバー
6のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 20
今までの合計 1,376
