メインコンテンツにスキップ
HP Compaq 6730b Switch Cover Replacement
必要な工具と部品
  1. HP Compaq 6730b Switch Cover Replacement, Switch Cover: 手順 1、 3の画像 1 HP Compaq 6730b Switch Cover Replacement, Switch Cover: 手順 1、 3の画像 2 HP Compaq 6730b Switch Cover Replacement, Switch Cover: 手順 1、 3の画像 3
    • Shut down the computer. Disconnect all external devices connected to the computer. Disconnect the power from the computer by first unplugging the power cord from the AC outlet and then unplugging the AC adapter from the computer.
    • Close the screen and turn the computer over. Loosen the three Phillips 2.5×9.0 captive screws that secure the keyboard to the computer. They are secured by a spring clip at the back, so they will not be easily removed. All that is required is to loosen those.
    • Turn the computer display-side up, with the front toward you. Open the computer as far as possible. There are four retention tabs that hold the keyboard down.
  2. HP Compaq 6730b Switch Cover Replacement: 手順 2、 3の画像 1 HP Compaq 6730b Switch Cover Replacement: 手順 2、 3の画像 2 HP Compaq 6730b Switch Cover Replacement: 手順 2、 3の画像 3
    • Use a small screwdriver, or other instrument, to slide the four tabs in a downward direction toward the palmrest.
    • Gently lift the keyboard up from the display side,
    • and tilt it toward the front of the computer. Do not lift it up to fast or to high, the keyboard ribbon cable is still connected
  3. HP Compaq 6730b Switch Cover Replacement: 手順 3、 3の画像 1 HP Compaq 6730b Switch Cover Replacement: 手順 3、 3の画像 2 HP Compaq 6730b Switch Cover Replacement: 手順 3、 3の画像 3
    • Here is the keyboard ribbon cable seated in the zero insertion force (Zif) connector. The keyboard is now separated and can now be removed.
    • Release the Zif connector to which the power button board cable is connected, by lifting the clasp of the Zif connector in an upward direction.
    • Lift the left and right sides of the switch cover until it detaches from the computer, but do not yet try to remove it.
  4. HP Compaq 6730b Switch Cover Replacement: 手順 4、 2の画像 1 HP Compaq 6730b Switch Cover Replacement: 手順 4、 2の画像 2
    • The LED board cable is still attached, disconnect it from the Zif connector by simply pulling it out in an upward direction.
    • With both ribbon cables disconnected, remove the switch cover.
終わりに
5 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
oldturkey03
メンバー登録日: 09/29/10
784,351 ポイント
119のガイドは作成済み
チーム
Global Fixers Global Fixers人のメンバー
Community
33 メンバー
560のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 22
今までの合計 2,385
