メインコンテンツにスキップ
HP Compaq 6710b Screen Replacement
必要な工具と部品
  1. HP Compaq 6710b Screen Replacement, Battery: 手順 1、 1の画像 1
    • Turn off your computer! Taking out the battery while it's still on is dangerous!
    • Flip the laptop over to the back.
    • Using two hands, push on the tabs while gently taking out the battery.
  2. HP Compaq 6710b Screen Replacement, Keyboard: 手順 2、 3の画像 1 HP Compaq 6710b Screen Replacement, Keyboard: 手順 2、 3の画像 2 HP Compaq 6710b Screen Replacement, Keyboard: 手順 2、 3の画像 3
    • Turn off computer before starting.
    • Flip to the backside of the laptop.
    • Using a Phillips #1 screwdriver, unscrew the 5mm screw and take off the shown cover.
    • Using the same screwdriver, unscrew the 8mm screws.
    • The screws may not completely fall out of the laptop, just ensure they are unscrewed as far as they will go.
  3. HP Compaq 6710b Screen Replacement: 手順 3、 1の画像 1
    • Flip over the laptop to the top side, and open the laptop.
    • Slide the locking tabs down using a blue plastic opening tool or your fingernail.
  4. HP Compaq 6710b Screen Replacement: 手順 4、 2の画像 1 HP Compaq 6710b Screen Replacement: 手順 4、 2の画像 2
    • Using the plastic prying tool, lift the keyboard gently towards you.
    • Don't take the keyboard completely off because it is still attached with a ribbon cable to the computer.
  5. HP Compaq 6710b Screen Replacement: 手順 5、 1の画像 1
    • Pull up on both sides of the black locking tab of the connector.
    • The keyboard should now be free of the computer.
  6. HP Compaq 6710b Screen Replacement, Power Button Panel: 手順 6、 1の画像 1
    • Put a finger under each side of the plastic lock on the ribbon cable and pull up.
  7. HP Compaq 6710b Screen Replacement: 手順 7、 3の画像 1 HP Compaq 6710b Screen Replacement: 手順 7、 3の画像 2 HP Compaq 6710b Screen Replacement: 手順 7、 3の画像 3
    • Using a flathead screwdriver, get under each plastic hinge cover until they pop.
    • Lift the right edge of plastic strip covering the power button and gently pull it up until the whole strip comes free.
  8. HP Compaq 6710b Screen Replacement, Screen: 手順 8、 1の画像 1
    • Using a flathead screwdriver, work both sides of the connector next to the fan and take it out.
  9. HP Compaq 6710b Screen Replacement: 手順 9、 1の画像 1
    • Using the T9 Torx screwdriver, remove one 7mm screw on the left hinge.
    • We recommend replacing this screw shortly after removing the cable as it helps hold the hinge to the lower half of the laptop.
  10. HP Compaq 6710b Screen Replacement: 手順 10、 1の画像 1
    • Using the blue plastic opening tool, pull the rubber covers off the screen screws.
  11. HP Compaq 6710b Screen Replacement: 手順 11、 1の画像 1
    • Using a T9 Torx screwdriver, remove the top four 5 mm screws.
    • Remove the bottom two 6 mm screws with the same screwdriver.
  12. HP Compaq 6710b Screen Replacement: 手順 12、 3の画像 1 HP Compaq 6710b Screen Replacement: 手順 12、 3の画像 2 HP Compaq 6710b Screen Replacement: 手順 12、 3の画像 3
    • Using a flat head screwdriver, pry the plastic panel over the screen up starting at one of the hinges.
    • Using the flathead, continue running the it under the the plastic screen edge and gently pry it off.
    • If you press the screwdriver tip down (by lifting the handle), the screen panel pops off easier.
  13. HP Compaq 6710b Screen Replacement: 手順 13、 3の画像 1 HP Compaq 6710b Screen Replacement: 手順 13、 3の画像 2 HP Compaq 6710b Screen Replacement: 手順 13、 3の画像 3
    • Slowly pry back the of the screen.
    • It is easiest to work both sides free at the same time.
  14. HP Compaq 6710b Screen Replacement: 手順 14、 1の画像 1
    • Using your fingers, take out the two connections near the hinges.
  15. HP Compaq 6710b Screen Replacement: 手順 15、 1の画像 1
    • Using the T9 Torx screwdriver, unscrew the four 4mm screws.
  16. HP Compaq 6710b Screen Replacement: 手順 16、 2の画像 1 HP Compaq 6710b Screen Replacement: 手順 16、 2の画像 2
    • Tilt the screen up from the top to gain access to the screws on the side.
    • Go just far enough to get to the bottom screws to avoid damaging the bracket.
    • Using the PH00 screwdriver, unscrew the 2.5mm screws on the side of the screen. There should be 4 on each side.
    • You can now take out the screen.
終わりに
8 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Khulan Orgil
メンバー登録日: 04/14/15
1,171 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 4-2, Maness Spring 2015 Cal Poly, Team 4-2, Maness Spring 2015人のメンバー
CPSU-MANESS-S15S4G2
4 メンバー
6のガイドは作成済み
1件のガイドコメント
thank you I found it very interesting
Hassan - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 26
今までの合計 5,811
