メインコンテンツにスキップ
HP Compaq 6710b Heat Sink Replacement
必要な工具と部品
  1. HP Compaq 6710b Heat Sink Replacement, Battery: 手順 1、 1の画像 1
    • Turn off your computer! Taking out the battery while it's still on is dangerous!
    • Flip the laptop over to the back.
    • Using two hands, push on the tabs while gently taking out the battery.
  2. HP Compaq 6710b Heat Sink Replacement, Keyboard: 手順 2、 3の画像 1 HP Compaq 6710b Heat Sink Replacement, Keyboard: 手順 2、 3の画像 2 HP Compaq 6710b Heat Sink Replacement, Keyboard: 手順 2、 3の画像 3
    • Turn off computer before starting.
    • Flip to the backside of the laptop.
    • Using a Phillips #1 screwdriver, unscrew the 5mm screw and take off the shown cover.
    • Using the same screwdriver, unscrew the 8mm screws.
    • The screws may not completely fall out of the laptop, just ensure they are unscrewed as far as they will go.
  3. HP Compaq 6710b Heat Sink Replacement: 手順 3、 1の画像 1
    • Flip over the laptop to the top side, and open the laptop.
    • Slide the locking tabs down using a blue plastic opening tool or your fingernail.
  4. HP Compaq 6710b Heat Sink Replacement: 手順 4、 2の画像 1 HP Compaq 6710b Heat Sink Replacement: 手順 4、 2の画像 2
    • Using the plastic prying tool, lift the keyboard gently towards you.
    • Don't take the keyboard completely off because it is still attached with a ribbon cable to the computer.
  5. HP Compaq 6710b Heat Sink Replacement: 手順 5、 1の画像 1
    • Pull up on both sides of the black locking tab of the connector.
    • The keyboard should now be free of the computer.
  6. HP Compaq 6710b Heat Sink Replacement, Power Button Panel: 手順 6、 1の画像 1
    • Put a finger under each side of the plastic lock on the ribbon cable and pull up.
    Reben pack Tut Gaya hai
    Gopal Ji - 返信
    Reben cabal tuta huahai
    Gopal Ji - 返信
  7. HP Compaq 6710b Heat Sink Replacement: 手順 7、 3の画像 1 HP Compaq 6710b Heat Sink Replacement: 手順 7、 3の画像 2 HP Compaq 6710b Heat Sink Replacement: 手順 7、 3の画像 3
    • Using a flathead screwdriver, get under each plastic hinge cover until they pop.
    • Lift the right edge of plastic strip covering the power button and gently pull it up until the whole strip comes free.
  8. HP Compaq 6710b Heat Sink Replacement, Heat Sink: 手順 8、 1の画像 1
    • Using two fingers, open the prongs holding the RAM
    • Then slide the RAM out from the socket
  9. HP Compaq 6710b Heat Sink Replacement: 手順 9、 1の画像 1
    • Using a Phillips #1 screwdriver, unscrew the two 7mm screws on the top and bottom of the fan.
  10. HP Compaq 6710b Heat Sink Replacement: 手順 10、 3の画像 1 HP Compaq 6710b Heat Sink Replacement: 手順 10、 3の画像 2 HP Compaq 6710b Heat Sink Replacement: 手順 10、 3の画像 3
    • Using two fingers, pull out the fan power connector.
    • To take out the fan, lift the bottom of the fan and take it out at an angle.
  11. HP Compaq 6710b Heat Sink Replacement: 手順 11、 1の画像 1
    • Using the Phillips #1 screwdriver, unscrew the four screws on the copper plate.
    • The screws on the copper plate do not come all the way out.
  12. HP Compaq 6710b Heat Sink Replacement: 手順 12、 2の画像 1 HP Compaq 6710b Heat Sink Replacement: 手順 12、 2の画像 2
    • Rotate the copper plate heat sink to slide it out.
    • Do not force the heat sink because it's easy to damage.
終わりに
9 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Khulan Orgil
メンバー登録日: 04/14/15
1,171 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 4-2, Maness Spring 2015 Cal Poly, Team 4-2, Maness Spring 2015人のメンバー
CPSU-MANESS-S15S4G2
4 メンバー
6のガイドは作成済み
3 件のコメント
That was easy. Thanks man :)
Florian Kasimir - 返信
благодаря за инструкцията!
kirovr - 返信
Piece of cake ! Thanks. :)
Pierre Delanoy - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 10
過去 30 日: 24
今までの合計 4,200
