メインコンテンツにスキップ
HP Compaq 6510b Fan Replacement
必要な工具と部品
  1. HP Compaq 6510b Fan Replacement, Battery: 手順 1、 2の画像 1 HP Compaq 6510b Fan Replacement, Battery: 手順 1、 2の画像 2
    • Flip the computer over so the backside is facing you.
    • Using the two prongs that are located in the back, slide the further left prong and the upper right prong to the left as indicated in the image.
    • Slide the battery out.
  2. HP Compaq 6510b Fan Replacement, RAM: 手順 2、 2の画像 1 HP Compaq 6510b Fan Replacement, RAM: 手順 2、 2の画像 2
    • Flip your device over.
    • In the center of the bottom of the laptop, there is a panel with two screws. Using the JIS #1 screw head unscrew both.
    • Lift the panel.
  3. HP Compaq 6510b Fan Replacement: 手順 3、 3の画像 1 HP Compaq 6510b Fan Replacement: 手順 3、 3の画像 2 HP Compaq 6510b Fan Replacement: 手順 3、 3の画像 3
    • The RAM is held down by two prongs. Gently pull them until the RAM pops out of place.
    • Lift the RAM out of place.
  4. HP Compaq 6510b Fan Replacement, Fan: 手順 4、 1の画像 1
    • Look for tabs in between esc and f1, f4 and f5, f8 and f9, f12 and scroll.
    • Pull these tabs towards you.
  5. HP Compaq 6510b Fan Replacement: 手順 5、 2の画像 1 HP Compaq 6510b Fan Replacement: 手順 5、 2の画像 2
    • Flip the laptop over and on the back of the center of the keyboard there is a screw with a rectangle beside it that looks like a keyboard. Remove this Phillips 5mm screw and another similar screw in the back top left of the keyboard.
    • Then carefully lift the keyboard out of place with your fingernails or a plastic opening tool.
  6. HP Compaq 6510b Fan Replacement: 手順 6、 3の画像 1 HP Compaq 6510b Fan Replacement: 手順 6、 3の画像 2 HP Compaq 6510b Fan Replacement: 手順 6、 3の画像 3
    • There will be a metallic film attached to the keyboard from the motherboard. A black latch runs along the film keeping it in place. Lift the latch and detach the film; remove it to fully remove the keyboard.
  7. HP Compaq 6510b Fan Replacement: 手順 7、 3の画像 1 HP Compaq 6510b Fan Replacement: 手順 7、 3の画像 2 HP Compaq 6510b Fan Replacement: 手順 7、 3の画像 3
    • Carefully undo the white film the same way you took out the metallic film
    • Once this film is removed the bar with the power button and media tools above the keyboard will pop out of place using a spudger.
  8. HP Compaq 6510b Fan Replacement: 手順 8、 2の画像 1 HP Compaq 6510b Fan Replacement: 手順 8、 2の画像 2
    • Underneath, a metal clamp will be revealed with two Torx Security T7 17mm screws. Unscrew these.
    • Carefully lift the cable out of place that is to the right of it.
  9. HP Compaq 6510b Fan Replacement: 手順 9、 2の画像 1 HP Compaq 6510b Fan Replacement: 手順 9、 2の画像 2
    • Unscrew these two JIS #1 5mm screws on the fan.
    • Carefully unplug the fans' wires.
    • Remove the fan and put in new one.
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Joseph Noudom
メンバー登録日: 03/01/18
569 ポイント
4のガイドは作成済み
チーム
UMass Dartmouth, Team S2-G5, Simcock Spring 2018 UMass Dartmouth, Team S2-G5, Simcock Spring 2018人のメンバー
UMASSD-SIMCOCK-S18S2G5
3 メンバー
5のガイドは作成済み
コメント 1 件
Many Thanks!
BTW, my German keyboard was held by a 3rd screw. In step 3, one needs to remove the remaining screw next to the WIFI module as well.
Torsten Spengler - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 16
今までの合計 1,143
