メインコンテンツにスキップ
HP Compaq 6510b CD Drive Replacement
必要な工具と部品
  1. HP Compaq 6510b CD Drive Replacement, Battery: 手順 1、 2の画像 1 HP Compaq 6510b CD Drive Replacement, Battery: 手順 1、 2の画像 2
    • Flip the computer over so the backside is facing you.
    • Using the two prongs that are located in the back, slide the further left prong and the upper right prong to the left as indicated in the image.
    • Slide the battery out.
  2. HP Compaq 6510b CD Drive Replacement, Fan: 手順 2、 1の画像 1
    • Look for tabs in between esc and f1, f4 and f5, f8 and f9, f12 and scroll.
    • Pull these tabs towards you.
  3. HP Compaq 6510b CD Drive Replacement: 手順 3、 2の画像 1 HP Compaq 6510b CD Drive Replacement: 手順 3、 2の画像 2
    • Flip the laptop over and on the back of the center of the keyboard there is a screw with a rectangle beside it that looks like a keyboard. Remove this Phillips 5mm screw and another similar screw in the back top left of the keyboard.
    • Then carefully lift the keyboard out of place with your fingernails or a plastic opening tool.
  4. HP Compaq 6510b CD Drive Replacement: 手順 4、 3の画像 1 HP Compaq 6510b CD Drive Replacement: 手順 4、 3の画像 2 HP Compaq 6510b CD Drive Replacement: 手順 4、 3の画像 3
    • There will be a metallic film attached to the keyboard from the motherboard. A black latch runs along the film keeping it in place. Lift the latch and detach the film; remove it to fully remove the keyboard.
  5. HP Compaq 6510b CD Drive Replacement: 手順 5、 3の画像 1 HP Compaq 6510b CD Drive Replacement: 手順 5、 3の画像 2 HP Compaq 6510b CD Drive Replacement: 手順 5、 3の画像 3
    • Carefully undo the white film the same way you took out the metallic film
    • Once this film is removed the bar with the power button and media tools above the keyboard will pop out of place using a spudger.
  6. HP Compaq 6510b CD Drive Replacement: 手順 6、 2の画像 1 HP Compaq 6510b CD Drive Replacement: 手順 6、 2の画像 2
    • Underneath, a metal clamp will be revealed with two Torx Security T7 17mm screws. Unscrew these.
    • Carefully lift the cable out of place that is to the right of it.
  7. HP Compaq 6510b CD Drive Replacement: 手順 7、 2の画像 1 HP Compaq 6510b CD Drive Replacement: 手順 7、 2の画像 2
    • Unscrew these two JIS #1 5mm screws on the fan.
    • Carefully unplug the fans' wires.
    • Remove the fan and put in new one.
  8. HP Compaq 6510b CD Drive Replacement, CD Drive: 手順 8、 3の画像 1 HP Compaq 6510b CD Drive Replacement, CD Drive: 手順 8、 3の画像 2 HP Compaq 6510b CD Drive Replacement, CD Drive: 手順 8、 3の画像 3
    • Push the CD drive out using your finger.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Joseph Noudom
メンバー登録日: 03/01/18
569 ポイント
4のガイドは作成済み
チーム
UMass Dartmouth, Team S2-G5, Simcock Spring 2018 UMass Dartmouth, Team S2-G5, Simcock Spring 2018人のメンバー
UMASSD-SIMCOCK-S18S2G5
3 メンバー
5のガイドは作成済み
コメント 1 件
I don’t know why these instructions are suggested but this is how you actually remove the disc drive. https://www.youtube.com/watch?v=gTvAt3Nn...
Cretien - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 13
今までの合計 541
