はじめに
This is a replacement guide for the power button on the HP Color LaserJet Pro MFP M277dw. You will need plastic opening tools as well as a Phillips #2 screwdriver.
必要な工具と部品
Lower the back panel by pulling it down.
Remove one Phillips #2 10mm screw.
Use the plastic opening tool to remove right side panel by prying it off.
Remove two Phillips #2 8mm screws.
Unplug the wire connecting the power button to the circuit board by gently pulling them apart.
What is the part number and where can I get it and the power module? How do you know which is defective?
ある他の人がこのガイドを完成しました。
2 件のコメント
How to make the catridge tray out ? As one side(left) of the tray is not coming out.
I am not sure if it’s the power button or power module. How do I determine that? Where do I get the parts?
