はじめに
This is a guide to replacing the display on an HP Color LaserJet Pro MFP M277dw. You should not need any special equipment or skills to perform this replacement.
必要な工具と部品
Unplug the display from pink cable from the circuit board.
This step could have used some further elaboration. As someone posted below, you can do it if you don’t try to follow the original path.
David Weld - 返信
5 の人々がこのガイドを完成させました。
8 件のコメント
where do you get a new screen
Would like to know too where to get a new screen
“Connecting a new display will require you to feed the cable through the printer”
Well, it’s actually not too complicated, you don’t need to take any additional parts to do it. Just take out the display (also need to unscrew two black screws inside, first and then grounding cable) and pull the cable out (do it a bit harder as it’s tight), and then when you change the display, feed the cable through by using different path.
In terms of finding the display, it’s not easy, as hp doesn’t sell it. You are may be lucky to find it on eBay…
looked on ebay could not find maybe you have another place
where we can get the new display could you advise.
Found a replacement touchscreen on eBay (“HP Printer Pros” in Texas) for $35.
David Weld - 返信
