はじめに
If the bottom cover of your HP Chromebox is damaged, it is easy to replace. This guide will take you through the steps of replacing the bottom cover. For this guide, you will need the Phillips #1 screwdriver and a plastic spudger.
必要な工具と部品
Position the device upside-down on a flat, level surface with the USB ports facing you.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
