はじめに
This guide demonstrates how to access the I/O Board on the HP Chromebook x360 14-da0011dx. This will allow users to remove and replace the I/O Board in their device. Before dissembling device and replacing I/O Board check I/O ports for deck and debris which may be interfering with connection. I/O Ports may also have bent receptacles that can be adjusted to fix connections issues.
必要な工具と部品
Flip the device over with the hinge facing away from you.
On the back of the device, remove the two rubber strips on the top and the bottom of the device using a spudger.
Locate the I/O Board on the top left of the laptop.
Remove the four 3.0 mm screws with the Phillips #1 screwdriver.
