メインコンテンツにスキップ
HP Chromebook 14-x013dx I/O Board Replacement
必要な工具と部品
  1. HP Chromebook 14-x013dx I/O Board Replacement, Keyboard, Touchpad: 手順 1、 2の画像 1 HP Chromebook 14-x013dx I/O Board Replacement, Keyboard, Touchpad: 手順 1、 2の画像 2
    • Using the plastic spudger, gently lift the 5 rubber pads away from their seating.
  2. HP Chromebook 14-x013dx I/O Board Replacement: 手順 2、 1の画像 1
    • Remove the five 6mm screws located under the removed pads using Phillips #00 screwdriver.
  3. HP Chromebook 14-x013dx I/O Board Replacement: 手順 3、 2の画像 1 HP Chromebook 14-x013dx I/O Board Replacement: 手順 3、 2の画像 2
    • With the Phillips #00 screwdriver, remove the remaining eight 6mm screws. You will now have thirteen 6mm screws removed from the case.
  4. HP Chromebook 14-x013dx I/O Board Replacement: 手順 4、 2の画像 1 HP Chromebook 14-x013dx I/O Board Replacement: 手順 4、 2の画像 2
    • To continue removing the back cover, turn the laptop over as displayed.
    • Use the plastic spudger to gently pry around the base of the laptop from the back cover. Continue prying around the entire base of the laptop.
  5. HP Chromebook 14-x013dx I/O Board Replacement: 手順 5、 3の画像 1 HP Chromebook 14-x013dx I/O Board Replacement: 手順 5、 3の画像 2 HP Chromebook 14-x013dx I/O Board Replacement: 手順 5、 3の画像 3
    • Gently lift the silver base of the laptop from the bottom, but do not remove it.
    • To remove the ribbon cables, lift the latch holding the ribbon cables in place and then pull them free.
    • Remove the keyboard panel from the laptop.
  6. HP Chromebook 14-x013dx I/O Board Replacement, I/O Board: 手順 6、 2の画像 1 HP Chromebook 14-x013dx I/O Board Replacement, I/O Board: 手順 6、 2の画像 2
    • Unhook the ribbon connecting the I/O board and the battery.
    • To remove the ribbon, lift the latch holding the ribbons in place and then pull them free.
  7. HP Chromebook 14-x013dx I/O Board Replacement: 手順 7、 2の画像 1 HP Chromebook 14-x013dx I/O Board Replacement: 手順 7、 2の画像 2
    • Remove two 2mm screws from the I/O board using the Phillips PH00 screwdriver.
  8. HP Chromebook 14-x013dx I/O Board Replacement: 手順 8、 1の画像 1
    • Lift the I/O board out of the laptop case.
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
NHerbert
メンバー登録日: 09/28/17
602 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team S3-G6, Nance Fall 2017 USF Tampa, Team S3-G6, Nance Fall 2017人のメンバー
USFT-NANCE-F17S3G6
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 461
