メインコンテンツにスキップ
HP Chromebook 14-x010wm LCD Panel Replacement
必要な工具と部品
  1. HP Chromebook 14-x010wm LCD Panel Replacement, LCD Panel: 手順 1、 1の画像 1
    この手順で使用する道具:
    購入する
    • First, remove the 4 circled rubber feet on the base of the laptop to expose the screws beneath them.
    • If you experience difficulty removing them, use a pair of tweezers to aid in the removal.
  2. HP Chromebook 14-x010wm LCD Panel Replacement: 手順 2、 3の画像 1 HP Chromebook 14-x010wm LCD Panel Replacement: 手順 2、 3の画像 2 HP Chromebook 14-x010wm LCD Panel Replacement: 手順 2、 3の画像 3
    • Remove the 5.7mm screws from the back of the laptop.
    • Remember, there are screws located beneath the rubber feet removed in the previous step.
  3. HP Chromebook 14-x010wm LCD Panel Replacement: 手順 3、 1の画像 1
    • Open the laptop.
    • Use an opening tool to separate the keyboard assembly from the rest of the computer by prying the two pieces apart.
    • Do this along the perimeter of the keyboard assembly to ensure it is fully seperated.
    • Continue to the next step before removing the newly separated keyboard!
  4. HP Chromebook 14-x010wm LCD Panel Replacement: 手順 4、 1の画像 1
    • Once separated, carefully lift the keyboard assembly up and gently detach the two ribbon cables from the motherboard.
    • Lift the black ZIF tab that secures the cable. That will allow the cable to be pulled out freely.
  5. HP Chromebook 14-x010wm LCD Panel Replacement: 手順 5、 3の画像 1 HP Chromebook 14-x010wm LCD Panel Replacement: 手順 5、 3の画像 2 HP Chromebook 14-x010wm LCD Panel Replacement: 手順 5、 3の画像 3
    • Detatch the display ribbon cable from the motherboard.
    • Gently pull the the black and white coaxial Wi-Fi cables from the motherboard.
    • The ribbon cable can be removed as in the previous step. To remove the coaxial cables, use the opening tool to pop them off their terminals.
  6. HP Chromebook 14-x010wm LCD Panel Replacement: 手順 6、 1の画像 1
    • This step is optional but will greatly decrease the difficulty of the rest of the assembly.
    • To separate the screen assembly from the rest of the computer, remove the two screws that hold the hinges in place using the #00 phillips screwdriver.
    • The screen assembly can now be separated from the rest of the laptop.
  7. HP Chromebook 14-x010wm LCD Panel Replacement: 手順 7、 2の画像 1 HP Chromebook 14-x010wm LCD Panel Replacement: 手順 7、 2の画像 2
    • Next, using the opening tool to sperate the frame from the screen-assembly backing.
    • Insert the opening tool at the base and work around the perimeter. It may be necessary to use the tool on the inside perimeter of the frame.
    • There is also glue holding the assembly together, so take your time. It may take a few passes with the opening tool before the parts separate.
  8. HP Chromebook 14-x010wm LCD Panel Replacement: 手順 8、 3の画像 1 HP Chromebook 14-x010wm LCD Panel Replacement: 手順 8、 3の画像 2 HP Chromebook 14-x010wm LCD Panel Replacement: 手順 8、 3の画像 3
    • Before the screen can be removed, the hinges need to be taken out of the screen assembly.
    • There are 4 screws holding each hinge in place: 3 at the base and 1 at the top. Use the #00 Phillips screwdriver to remove them.
    • Once all the screws are removed, the hinges can be lifted out.
  9. HP Chromebook 14-x010wm LCD Panel Replacement: 手順 9、 2の画像 1 HP Chromebook 14-x010wm LCD Panel Replacement: 手順 9、 2の画像 2
    • Remove the four Phillips #00 screws that secure the screen.
    • There are two at the base and two on the opposite side of the screen at the top.
  10. HP Chromebook 14-x010wm LCD Panel Replacement: 手順 10、 2の画像 1 HP Chromebook 14-x010wm LCD Panel Replacement: 手順 10、 2の画像 2
    • Once the screws are removed, the screen can be lifted out, but it is still attached by a ribbon cable.
    • As you lift out the screen, be sure to detach the ribbon cable from the back.
    • If necessary, untuck the cables connected to the screen from the plastic hooks that hold them in place.
    • With that, you have successfully removed the screen from your HP Chromebook! Reverse the steps to install a new screen.
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
William Broshears
メンバー登録日: 03/30/22
211 ポイント
1ガイドが承認済み
チーム
IUPUI, Team 1-1, Harley Spring 2022 IUPUI, Team 1-1, Harley Spring 2022人のメンバー
IUPUI-HARLEY-S22S1G1
4 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 152
