はじめに
Utilize this guide if you need to replace the battery in an HP Chromebook 14-x010wm laptop, or if you need to remove the battery as a prerequisite step in other repair procedures. Removing the battery requires removing the keyboard cover and a number of connectors to other components. It is important to proceed carefully through this procedure to avoid damaging other components.
必要な工具と部品
Remove the thirteen 5.7mm screws from the back of the laptop using a Phillips #00 screwdriver.
Lift the black plastic flap, using a plastic opening tool, of the zero insertion force (ZIF) connector that holds the keyboard cable in place.
Disconnect the keyboard cable by slowly pulling it from the system board.
Lift the black plastic flap that holds the battery cable in place using a plastic opening tool.
Remove the battery cable by slowly pulling the plastic connector towards you.
Remove carefully and set aside keyboard panel.
Follow these instructions in reverse order to reassemble your device.
