メインコンテンツにスキップ
HP Chromebook 14-x010wm Battery Replacement
必要な工具と部品
  1. HP Chromebook 14-x010wm Battery Replacement, Battery: 手順 1、 3の画像 1 HP Chromebook 14-x010wm Battery Replacement, Battery: 手順 1、 3の画像 2 HP Chromebook 14-x010wm Battery Replacement, Battery: 手順 1、 3の画像 3
    • Remove the thirteen 5.7mm screws from the back of the laptop using a Phillips #00 screwdriver.
    • Remove rubber covers to reveal concealed screws, as needed.
  2. HP Chromebook 14-x010wm Battery Replacement: 手順 2、 3の画像 1 HP Chromebook 14-x010wm Battery Replacement: 手順 2、 3の画像 2 HP Chromebook 14-x010wm Battery Replacement: 手順 2、 3の画像 3
    • Flip the laptop over carefully and open the cover.
    • Use a plastic opening tool to pry open the front edge and along the sides of the keyboard cover to separate it from the computer’s base.
    • Lift the keyboard cover from the computer’s base carefully.
  3. HP Chromebook 14-x010wm Battery Replacement: 手順 3、 3の画像 1 HP Chromebook 14-x010wm Battery Replacement: 手順 3、 3の画像 2 HP Chromebook 14-x010wm Battery Replacement: 手順 3、 3の画像 3
    • Lifting the keyboard cover too much may damage the internal cables of the laptop.
    • Lift the black plastic flap, using a plastic opening tool, of the zero insertion force (ZIF) connector that holds the keyboard cable in place.
    • Disconnect the keyboard cable by slowly pulling it from the system board.
    • Lift the black plastic flap that holds the battery cable in place using a plastic opening tool.
    • Remove the battery cable by slowly pulling the plastic connector towards you.
    • Remove carefully and set aside keyboard panel.
  4. HP Chromebook 14-x010wm Battery Replacement: 手順 4、 2の画像 1 HP Chromebook 14-x010wm Battery Replacement: 手順 4、 2の画像 2
    • Flip the plastic flap holding the battery cable using a plastic opening tool.
    • Disconnect the battery cable by carefully pulling it from the system board.
  5. HP Chromebook 14-x010wm Battery Replacement: 手順 5、 3の画像 1 HP Chromebook 14-x010wm Battery Replacement: 手順 5、 3の画像 2 HP Chromebook 14-x010wm Battery Replacement: 手順 5、 3の画像 3
    • Remove the seven M2xL3.0 screws from around the battery using a Phillips #00 screwdriver.
  6. HP Chromebook 14-x010wm Battery Replacement: 手順 6、 2の画像 1 HP Chromebook 14-x010wm Battery Replacement: 手順 6、 2の画像 2
    • Peel the wire band off of the battery carefully.
    • Remove the battery by lifting slightly, then slowly pull it towards you.
終わりに
Follow these instructions in reverse order to reassemble your device.
作成者
4人の作成者と共同で作成されました。
Tyler Stover
メンバー登録日: 04/02/19
137 ポイント
1ガイドが承認済み
チーム
IUPUI, Team S3-G3, Harley Spring 2019 IUPUI, Team S3-G3, Harley Spring 2019人のメンバー
IUPUI-HARLEY-S19S3G3
3 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 7
今までの合計 382
