メインコンテンツにスキップ
HP Chromebook 14-q010nr Motherboard Replacement
必要な工具と部品
  1. HP Chromebook 14-q010nr Motherboard Replacement, Battery: 手順 1、 1の画像 1
    • Begin by turning the Chromebook onto its back.
    • Remove the 15 screws with a Phillips #0 screwdriver.
    • Four screws will be located underneath the device's rubber foot pads.
  2. HP Chromebook 14-q010nr Motherboard Replacement: 手順 2、 3の画像 1 HP Chromebook 14-q010nr Motherboard Replacement: 手順 2、 3の画像 2 HP Chromebook 14-q010nr Motherboard Replacement: 手順 2、 3の画像 3
    • Remove the keyboard from the base plate with an opening pick to pry it open from both sides of the keyboard.
    • Beginning from the corners closest to the computer screen may result in easier disconnection.
  3. HP Chromebook 14-q010nr Motherboard Replacement: 手順 3、 1の画像 1
    • Use a Phillips #0 screwdriver to remove the seven screws securing the battery.
  4. HP Chromebook 14-q010nr Motherboard Replacement: 手順 4、 1の画像 1
    • Gently disconnect the battery's motherboard connection by pinching the white attachment and pulling the plug directly out of the port.
  5. HP Chromebook 14-q010nr Motherboard Replacement: 手順 5、 2の画像 1 HP Chromebook 14-q010nr Motherboard Replacement: 手順 5、 2の画像 2
    • Before removing the battery, gently lift the white ribbon cable taped to the battery.
    • Gently pull up from the back of the battery to remove it.
  6. HP Chromebook 14-q010nr Motherboard Replacement, Motherboard: 手順 6、 1の画像 1
    • Remove the eleven motherboard screws with a 2mm Phillips screwdriver.
  7. HP Chromebook 14-q010nr Motherboard Replacement: 手順 7、 1の画像 1
    • Remove the white ribbon cable from the motherboard by lifting the black ZIF connector.
  8. HP Chromebook 14-q010nr Motherboard Replacement: 手順 8、 1の画像 1
    • Remove the five screws attached to the connector plate.
    • Remove the monitor connector by lifting it gently upward.
  9. HP Chromebook 14-q010nr Motherboard Replacement: 手順 9、 1の画像 1
    • Remove the antenna cables on the right side of the motherboard.
    • Carefully lift the motherboard up to remove it. Use a spudger for ease.
終わりに
作成者
5人の作成者と共同で作成されました。
Julian Knight
メンバー登録日: 09/22/22
159 ポイント
1ガイドが承認済み
チーム
University of North Texas, Team 3-4, Saru Jimmy Fall 2022 University of North Texas, Team 3-4, Saru Jimmy Fall 2022人のメンバー
UNT-SARU JIMMY-F22S3G4
5 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 174
