はじめに
If you want to replace the RAM or CPU or the storage of the HP Chromebook 14-ca061dx or are in need of replacing those parts, you will need to replace the whole motherboard of the Chromebook since they are all combined to be part of it. You can follow this guide to replace the motherboard.
必要な工具と部品
Flip the Chromebook to the underside with the hinge at the top.
Remove the seven, small rubber stoppers using angled tweezers.
Peel back the black electrical tape from the wires connecting the battery to the motherboard using tweezers.
Pull the white plastic piece toward you using your finger to disconnect the wires.
