はじめに
This guide will walk you through the replacement of an old or corroded motherboard in your HP Chromebook 14-ak041dx. You may need to replace your motherboard if your Chromebook offers continuous slow performance. An upgrade may help it run faster.
必要な工具と部品
You will need a pair of tweezers and a Phillips screwdriver.
Remove eight 5mm Phillips #0 screws from the back cover of the laptop.
Remove the two 1.5mm Phillips #000 from the copper heat sink on top of the motherboard.
Remove the heat sink from the laptop.
Remove the single 2.5mm Phillips #00 screw from the wireless card.
Gently pull the wireless card from the motherboard to remove it.
Gently pull the wire connector with a pair of tweezers to free it from the motherboard.
Use a pair of tweezers to remove the black ribbon cable from its connector.
Use the tweezers to detach the wire connector from the bottom left corner of the motherboard.
