はじめに
This guide will walk you through the replacement of an old or corroded motherboard in your HP Chromebook 14-ak041dx. You may need to replace your motherboard if your Chromebook offers continuous slow performance. An upgrade may help it run faster.
必要な工具と部品
Remove the two 1.5mm Phillips #000 from the copper heat sink on top of the motherboard.
Remove the heat sink from the laptop.
Remove the single 2.5mm Phillips #00 screw from the wireless card.
Gently pull the wireless card from the motherboard to remove it.
もう少しです!
終わりに
