メインコンテンツにスキップ
HP Chromebook 14-ak013dx Touchpad Replacement
必要な工具と部品
  1. HP Chromebook 14-ak013dx Touchpad Replacement, Disassemble the Body: 手順 1、 3の画像 1 HP Chromebook 14-ak013dx Touchpad Replacement, Disassemble the Body: 手順 1、 3の画像 2 HP Chromebook 14-ak013dx Touchpad Replacement, Disassemble the Body: 手順 1、 3の画像 3
    • With the laptop upside down, remove the 13 screws with a P0 screwdriver (2 screws are located under the rubber footpads)
    • Open the screen, accessing the keyboard; gently pry the keyboard off the body careful not to pull out the ribbons
  2. HP Chromebook 14-ak013dx Touchpad Replacement, Disconnecting the Keyboard from the Body: 手順 2、 3の画像 1 HP Chromebook 14-ak013dx Touchpad Replacement, Disconnecting the Keyboard from the Body: 手順 2、 3の画像 2 HP Chromebook 14-ak013dx Touchpad Replacement, Disconnecting the Keyboard from the Body: 手順 2、 3の画像 3
    • Gently lift up the keyboard from the main body, careful not to pull out the ribbons
    • The black bars holding the ribbons in place will flip up with light pressure, releasing the ribbons
  3. HP Chromebook 14-ak013dx Touchpad Replacement, Disconnecting the Touchpad from the Keyboard: 手順 3、 3の画像 1 HP Chromebook 14-ak013dx Touchpad Replacement, Disconnecting the Touchpad from the Keyboard: 手順 3、 3の画像 2 HP Chromebook 14-ak013dx Touchpad Replacement, Disconnecting the Touchpad from the Keyboard: 手順 3、 3の画像 3
    • Separate the keyboard from the main body of the laptop
    • Using a P00 Screwdriver, remove the two screws holding the touchpad in place
    • Use light pressure to flip up the black bar holding the ribbon in place
  4. HP Chromebook 14-ak013dx Touchpad Replacement, Removing the Touchpad: 手順 4、 2の画像 1 HP Chromebook 14-ak013dx Touchpad Replacement, Removing the Touchpad: 手順 4、 2の画像 2
    • Use a tool to push down on the knob highlighted, the touchpad will fall out of the front of the keyboard
    • If not immediately replacing the touchpad, safely secure the old keyboard
終わりに
To reassemble your device, follow these instructions in reverse order. Ribbon guards should fall back into place securely. Keyboard should 'snap' back into place before the 13 screws.
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Cameron C Blanchard
メンバー登録日: 09/16/20
524 ポイント
4のガイドは作成済み
チーム
dwsad dwsad人のメンバー
Community
1 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 126
