メインコンテンツにスキップ
HP Chromebook 14-ak013dx Internal Speaker Replacement
必要な工具と部品
  1. HP Chromebook 14-ak013dx Internal Speaker Replacement, Disassembling the Body: 手順 1、 3の画像 1 HP Chromebook 14-ak013dx Internal Speaker Replacement, Disassembling the Body: 手順 1、 3の画像 2 HP Chromebook 14-ak013dx Internal Speaker Replacement, Disassembling the Body: 手順 1、 3の画像 3
    • Starting with the laptop on its back, remove the 13 screws holding the keyboard in place with a P00 screwdriver (2 screws are hidden behind the rubber footers)
    • Open the screen, revealing the keyboard. Using a prying tool, 'pop' the keyboard out by sliding the tool around the edge
  2. HP Chromebook 14-ak013dx Internal Speaker Replacement, Disconnect the Keyboard from the Body: 手順 2、 3の画像 1 HP Chromebook 14-ak013dx Internal Speaker Replacement, Disconnect the Keyboard from the Body: 手順 2、 3の画像 2 HP Chromebook 14-ak013dx Internal Speaker Replacement, Disconnect the Keyboard from the Body: 手順 2、 3の画像 3
    • Gently raise the keyboard from the body, careful not to rip out the ribbons
    • With light pressure, flip the black bar holding the ribbons in place, and remove the ribbons from the body
  3. HP Chromebook 14-ak013dx Internal Speaker Replacement, Remove the Keyboard: 手順 3、 1の画像 1
    • Completely remove the keyboard, place away from the body of the laptop
  4. HP Chromebook 14-ak013dx Internal Speaker Replacement, Remove the Battery: 手順 4、 3の画像 1 HP Chromebook 14-ak013dx Internal Speaker Replacement, Remove the Battery: 手順 4、 3の画像 2 HP Chromebook 14-ak013dx Internal Speaker Replacement, Remove the Battery: 手順 4、 3の画像 3
    • With a P00 Screwdriver, remove the 9 screws holding the battery in place
    • Gently pry the cable connecting the battery to the motherboard off
    • Battery will lift away from the body (screen will now be heavier than the body, be careful not to drop it)
  5. HP Chromebook 14-ak013dx Internal Speaker Replacement, Removing the Left Speaker: 手順 5、 2の画像 1 HP Chromebook 14-ak013dx Internal Speaker Replacement, Removing the Left Speaker: 手順 5、 2の画像 2
    • Gently disconnect the cable connecting the internal speaker to the motherboard
    • Using a P00 Screwdriver, remove the final screw from the left speaker
    • Using a prying tool, carefully remove the speaker out of the body
  6. HP Chromebook 14-ak013dx Internal Speaker Replacement, Removing the Right Speaker: 手順 6、 2の画像 1 HP Chromebook 14-ak013dx Internal Speaker Replacement, Removing the Right Speaker: 手順 6、 2の画像 2
    • With a P00 Screwdriver, remove the final screw from the right speaker
    • Carefully remove the right internal speaker from the body
    • The entire speaker (barring some tape you may need to remove) should lift away from the body of the laptop
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Cameron C Blanchard
メンバー登録日: 09/16/20
524 ポイント
4のガイドは作成済み
チーム
dwsad dwsad人のメンバー
Community
1 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 4
今までの合計 87
