メインコンテンツにスキップ
HP Chromebook 14-ak013dx Battery Replacement
必要な工具と部品
  1. HP Chromebook 14-ak013dx Battery Replacement, Battery: 手順 1、 3の画像 1 HP Chromebook 14-ak013dx Battery Replacement, Battery: 手順 1、 3の画像 2 HP Chromebook 14-ak013dx Battery Replacement, Battery: 手順 1、 3の画像 3
    • Turn the Chromebook upside down, as shown in the first image.
    • Remove the five rubber feet pieces as shown using a metal spudger.
  2. HP Chromebook 14-ak013dx Battery Replacement: 手順 2、 3の画像 1 HP Chromebook 14-ak013dx Battery Replacement: 手順 2、 3の画像 2 HP Chromebook 14-ak013dx Battery Replacement: 手順 2、 3の画像 3
    • Begin removal of the back panel by unscrewing all exposed screws using a small Phillips screwdriver.
    • Use a plastic prying tool to split the back panel from the keyboard.
    • Move the prying tool around the sides of the back panel to detach it. Do not fully remove the panel, taking note of the two ribbon cables.
  3. HP Chromebook 14-ak013dx Battery Replacement: 手順 3、 3の画像 1 HP Chromebook 14-ak013dx Battery Replacement: 手順 3、 3の画像 2 HP Chromebook 14-ak013dx Battery Replacement: 手順 3、 3の画像 3
    • Remove both ribbon cables attaching the separated keyboard to the motherboard.
    • The large black ribbon cable was a tab that should be pried open to loosen the ribbon from its hub. Use the plastic opening tool as shown.
    • Gently pull out the short white ribbon cable out of its hub.
  4. HP Chromebook 14-ak013dx Battery Replacement: 手順 4、 2の画像 1 HP Chromebook 14-ak013dx Battery Replacement: 手順 4、 2の画像 2
    • Peel up the adhered ribbon cable. This cable does not need to be detached from the motherboard.
    • Use a plastic opening tool to disconnect the battery before going any further by inserting the tool between the plug and the hub where the recesses are on either side of the plug.
  5. HP Chromebook 14-ak013dx Battery Replacement: 手順 5、 2の画像 1 HP Chromebook 14-ak013dx Battery Replacement: 手順 5、 2の画像 2
    • Unscrew the four M2xL3 screws , shown in the picture, using a Phillips screwdriver.
    • Carefully lift the battery out of its place, avoiding the previously adhered silver ribbon cable in the process.
終わりに
作成者
3人の作成者と共同で作成されました。
Nicholas Molargik
メンバー登録日: 11/01/18
277 ポイント
2のガイドは作成済み
チーム
IUPUI, Team S3-G5, Harley Fall 2018 IUPUI, Team S3-G5, Harley Fall 2018人のメンバー
IUPUI-HARLEY-F18S3G5
3 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 594
