メインコンテンツにスキップ
HP Chromebook 14-Q070NR Display Replacement
必要な工具と部品
  1. HP Chromebook 14-Q070NR Display Replacement, Keyboard: 手順 1、 1の画像 1
    • At this point, the white caps that hide the top-most screws marked with red circles have been removed.
    • Using the Phillips #1 screwdriver, remove the (10) ten screws from the bottom of the device.
    • After removing the white caps covering the screws, use the Phillips #1 screwdriver to remove the (3) three screws indicated with red circles.
  2. HP Chromebook 14-Q070NR Display Replacement: 手順 2、 3の画像 1 HP Chromebook 14-Q070NR Display Replacement: 手順 2、 3の画像 2 HP Chromebook 14-Q070NR Display Replacement: 手順 2、 3の画像 3
    • Open the laptop and place it upright. Remove the keyboard from the device using a plastic spudger or opening tool.
    • Carefully remove as there are ribbons attached to the keyboard that is connected to the components inside.
    • Gently lift the keyboard just enough to expose the ribbons.
  3. HP Chromebook 14-Q070NR Display Replacement: 手順 3、 3の画像 1 HP Chromebook 14-Q070NR Display Replacement: 手順 3、 3の画像 2 HP Chromebook 14-Q070NR Display Replacement: 手順 3、 3の画像 3
    • Hold the keyboard up to remove the ribbons from the circuit board.
    • To remove each individual ribbon, grab the blue portion of each ribbon and pull it towards your direction until it is fully detached.
  4. HP Chromebook 14-Q070NR Display Replacement: 手順 4、 3の画像 1 HP Chromebook 14-Q070NR Display Replacement: 手順 4、 3の画像 2 HP Chromebook 14-Q070NR Display Replacement: 手順 4、 3の画像 3
    • Once the ribbons are detached, remove the keyboard from the device.
  5. HP Chromebook 14-Q070NR Display Replacement, Display: 手順 5、 1の画像 1
    • Unplug the cable located in the upper left corner of the device.
  6. HP Chromebook 14-Q070NR Display Replacement: 手順 6、 1の画像 1
    • Remove these tabs located at each of the bottom corners of the display.
    • It is not necessary for the display to be completely removed from the device in order to complete this guide.
    • Using the Phillips #1 screwdriver, remove the single screw located under each of the two tabs.
  7. HP Chromebook 14-Q070NR Display Replacement: 手順 7、 1の画像 1
    • Insert the plastic opening tool and work it around the entire frame of the display.
  8. HP Chromebook 14-Q070NR Display Replacement: 手順 8、 2の画像 1 HP Chromebook 14-Q070NR Display Replacement: 手順 8、 2の画像 2
    • As you work the plastic opening tool around the edge, remove the front frame of the device.
  9. HP Chromebook 14-Q070NR Display Replacement: 手順 9、 3の画像 1 HP Chromebook 14-Q070NR Display Replacement: 手順 9、 3の画像 2 HP Chromebook 14-Q070NR Display Replacement: 手順 9、 3の画像 3
    • Using the Phillips #1 screwdriver, remove the (4) four screws located at the bottom of the display.
    • Once the screws are removed, lift the display out of the device.
終わりに
作成者
1人の作成者と共同作成されました。
Richard Underwood
メンバー登録日: 10/02/17
101 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team S9-G5, Remmell Fall 2017 USF Tampa, Team S9-G5, Remmell Fall 2017人のメンバー
USFT-REMMELL-F17S9G5
5 メンバー
5のガイドは作成済み
コメント 1 件
This was very helpful, I broke the screen to my chromebook whilst shutting the lid and the screen cracked. I didn’t want to spend the money on a new screen so I decided to take the whole top half off the chomebook and basically make a chromebox.
quardpd - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 10
今までの合計 282
