メインコンテンツにスキップ
HP Chromebook 14-Q070NR Battery Replacement
必要な工具と部品
  1. HP Chromebook 14-Q070NR Battery Replacement, Keyboard: 手順 1、 1の画像 1
    • At this point, the white caps that hide the top-most screws marked with red circles have been removed.
    • Using the Phillips #1 screwdriver, remove the (10) ten screws from the bottom of the device.
    • After removing the white caps covering the screws, use the Phillips #1 screwdriver to remove the (3) three screws indicated with red circles.
  2. HP Chromebook 14-Q070NR Battery Replacement: 手順 2、 3の画像 1 HP Chromebook 14-Q070NR Battery Replacement: 手順 2、 3の画像 2 HP Chromebook 14-Q070NR Battery Replacement: 手順 2、 3の画像 3
    • Open the laptop and place it upright. Remove the keyboard from the device using a plastic spudger or opening tool.
    • Carefully remove as there are ribbons attached to the keyboard that is connected to the components inside.
    • Gently lift the keyboard just enough to expose the ribbons.
  3. HP Chromebook 14-Q070NR Battery Replacement: 手順 3、 3の画像 1 HP Chromebook 14-Q070NR Battery Replacement: 手順 3、 3の画像 2 HP Chromebook 14-Q070NR Battery Replacement: 手順 3、 3の画像 3
    • Hold the keyboard up to remove the ribbons from the circuit board.
    • To remove each individual ribbon, grab the blue portion of each ribbon and pull it towards your direction until it is fully detached.
  4. HP Chromebook 14-Q070NR Battery Replacement: 手順 4、 3の画像 1 HP Chromebook 14-Q070NR Battery Replacement: 手順 4、 3の画像 2 HP Chromebook 14-Q070NR Battery Replacement: 手順 4、 3の画像 3
    • Once the ribbons are detached, remove the keyboard from the device.
  5. HP Chromebook 14-Q070NR Battery Replacement, Battery: 手順 5、 1の画像 1
    • Using the Phillips #0 screwdriver, remove the (2) two screws at the bottom of the device.
    • Once removed, separate the screws from previous ones. They are different!
  6. HP Chromebook 14-Q070NR Battery Replacement: 手順 6、 2の画像 1 HP Chromebook 14-Q070NR Battery Replacement: 手順 6、 2の画像 2
    • Remove the taped flat wire from the top of the battery.
    • Carefully pull away the connector from the top of the battery to the motherboard.
  7. HP Chromebook 14-Q070NR Battery Replacement: 手順 7、 1の画像 1
    • Carefully lift the battery and remove it from the device.
終わりに
作成者
1人の作成者と共同作成されました。
Andres Martinez
メンバー登録日: 10/02/17
101 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team S9-G5, Remmell Fall 2017 USF Tampa, Team S9-G5, Remmell Fall 2017人のメンバー
USFT-REMMELL-F17S9G5
5 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 411
