メインコンテンツにスキップ
HP Chromebook 14-Q010DX Bluetooth and Wireless Card Replacement
必要な工具と部品
  1. HP Chromebook 14-Q010DX Bluetooth and Wireless Card Replacement, Keyboard and Touchpad: 手順 1、 2の画像 1 HP Chromebook 14-Q010DX Bluetooth and Wireless Card Replacement, Keyboard and Touchpad: 手順 1、 2の画像 2
    • Flip the laptop with the base of the laptop is facing you.
    • Using the #00 screwdriver, unscrew these screws.
  2. HP Chromebook 14-Q010DX Bluetooth and Wireless Card Replacement: 手順 2、 3の画像 1 HP Chromebook 14-Q010DX Bluetooth and Wireless Card Replacement: 手順 2、 3の画像 2 HP Chromebook 14-Q010DX Bluetooth and Wireless Card Replacement: 手順 2、 3の画像 3
    • Warning! When prying open a laptop it could require some force, but it also has fragile connectors underneath. Use caution so as to avoid breaking these connectors.
    • Start from the top right corner of the laptop and work clockwise with an iFixit opening tool or spudger to pry the keyboard from the frame of the laptop.
  3. HP Chromebook 14-Q010DX Bluetooth and Wireless Card Replacement: 手順 3、 3の画像 1 HP Chromebook 14-Q010DX Bluetooth and Wireless Card Replacement: 手順 3、 3の画像 2 HP Chromebook 14-Q010DX Bluetooth and Wireless Card Replacement: 手順 3、 3の画像 3
    • Warning! Handle the flaps and ribbon cables with care to prevent damage.
    • Gently pull the keyboard in the opposite direction of the screen, so the wires beneath are exposed.
    • Lift the black flap and pull the blue ribbon gently towards you until it is disconnected.
    • Lift the white flap and pull the blue ribbon towards you until it is disconnected.
  4. HP Chromebook 14-Q010DX Bluetooth and Wireless Card Replacement: 手順 4、 1の画像 1
    • Lift keyboard slightly and remove the strip gently to prevent damaging any parts.
    • The tape has no function other than to keep the wire tucked away.
  5. HP Chromebook 14-Q010DX Bluetooth and Wireless Card Replacement: 手順 5、 1の画像 1
    • Set aside the detached keyboard.
  6. HP Chromebook 14-Q010DX Bluetooth and Wireless Card Replacement, Bluetooth and Wireless Card: 手順 6、 2の画像 1 HP Chromebook 14-Q010DX Bluetooth and Wireless Card Replacement, Bluetooth and Wireless Card: 手順 6、 2の画像 2
    • Using a spudger, remove the white and black cables from the card.
  7. HP Chromebook 14-Q010DX Bluetooth and Wireless Card Replacement: 手順 7、 2の画像 1 HP Chromebook 14-Q010DX Bluetooth and Wireless Card Replacement: 手順 7、 2の画像 2
    • Remove screw from card.
  8. HP Chromebook 14-Q010DX Bluetooth and Wireless Card Replacement: 手順 8、 1の画像 1
    • Gently pull card at a 45° angle to remove it.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Kevin Piper
メンバー登録日: 01/16/15
1,587 ポイント
6のガイドは作成済み
チーム
USF Tampa, Team 17-2, Watkins Winter 2015 USF Tampa, Team 17-2, Watkins Winter 2015人のメンバー
USFT-WATKINS-W15S17G2
4 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 6
今までの合計 1,668
