メインコンテンツにスキップ
HP Chromebook 11A G8 EE Screen Replacement
必要な工具と部品
  1. HP Chromebook 11A G8 EE Screen Replacement, Keyboard Assembly: 手順 1、 2の画像 1 HP Chromebook 11A G8 EE Screen Replacement, Keyboard Assembly: 手順 1、 2の画像 2
    • On the bottom of the laptop, remove four 7 mm screw using a Phillips #1 screwdriver.
    • Using the Phillips #1 screwdriver, remove the two remaining 8 mm screws by the hinges.
  2. HP Chromebook 11A G8 EE Screen Replacement: 手順 2、 3の画像 1 HP Chromebook 11A G8 EE Screen Replacement: 手順 2、 3の画像 2 HP Chromebook 11A G8 EE Screen Replacement: 手順 2、 3の画像 3
    • Flip the laptop over and open up the display.
    • Using the iFixit opening tool, carefully separate the palm rest from the bottom cover by working your way around the perimeter and prying it up.
    • You will hear an audible and tactile click or pop letting you know that you have unclipped a portion of the palm rest from the base enclosure.
    • Lift the palm rest of the laptops towards you, away from the screen.
  3. HP Chromebook 11A G8 EE Screen Replacement: 手順 3、 2の画像 1 HP Chromebook 11A G8 EE Screen Replacement: 手順 3、 2の画像 2
    • Carefully, lift the keyboard ribbon lock and disconnect the keyboard ribbon from the motherboard.
    • Disconnect the touchpad ribbon from the motherboard, and remove top cover.
    • Remove the keyboard.
  4. HP Chromebook 11A G8 EE Screen Replacement, Bezel: 手順 4、 1の画像 1
    • Pry the hinge cap off with your hands by lifting it up.
  5. HP Chromebook 11A G8 EE Screen Replacement: 手順 5、 1の画像 1
    • Use the iFixit opening tool to pry the bezel up.
  6. HP Chromebook 11A G8 EE Screen Replacement: 手順 6、 1の画像 1
    • Once you have pried away the bezel, pull it up towards you.
    • Peel it off gently from the screen.
  7. HP Chromebook 11A G8 EE Screen Replacement: 手順 7、 1の画像 1
    • You are finished once the bezel is off of the device.
  8. HP Chromebook 11A G8 EE Screen Replacement, Screen: 手順 8、 1の画像 1
    • Remove the four 3.5 mm screws with the Phillips #0 screwdriver.
  9. HP Chromebook 11A G8 EE Screen Replacement: 手順 9、 1の画像 1
    • Flip the screen towards you.
  10. HP Chromebook 11A G8 EE Screen Replacement: 手順 10、 1の画像 1
    この手順で使用する道具:
    購入する
    • Once the screen is flipped down, use the tweezers to peel away the black tape holding down the connector.
  11. HP Chromebook 11A G8 EE Screen Replacement: 手順 11、 1の画像 1
    • Next, peel away the tan tape, using the tweezers, exposing the screen connector.
  12. HP Chromebook 11A G8 EE Screen Replacement: 手順 12、 1の画像 1
    • Using the tweezers, remove the connector by the latch attached to it.
  13. HP Chromebook 11A G8 EE Screen Replacement: 手順 13、 1の画像 1
    • Finally, pull away the screen, to remove it from the device.
終わりに
8 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Kim Travers
メンバー登録日: 09/03/21
523 ポイント
2のガイドは作成済み
チーム
University of Alabama, Team 2-1, Bedsole Fall 2021 University of Alabama, Team 2-1, Bedsole Fall 2021人のメンバー
UA-BEDSOLE-F21S2G1
4 メンバー
7のガイドは作成済み
コメント 1 件
Does IFixit Sell this screen? I am unable to source parts and this screen for these educational units by HP. I wish iFixit would also list the parts that are needed for the repairs and not just the tools they sell.
Glenn Silva - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 12
過去 30 日: 57
今までの合計 3,207
