はじめに
Screens can become damaged in many ways. This guide will help replace the screen.
必要な工具と部品
Wedge the spudger between one of the black rubber caps on each of the four corners on the bottom of the HP Chromebook 11-v011dx.
Lift up the black rubber cap until it is completely removed.
Repeat this until all four of the black rubber caps are removed.
Use a Phillips #0 screwdriver to remove the 1.3 mm screw that holds the wireless card.
ある他の人がこのガイドを完成しました。
