はじめに
Through over-heating or damaging the laptop by dropping it, the motherboard will not be able to function. This guide will help replace it.
必要な工具と部品
Wedge the spudger between one of the black rubber caps on each of the four corners on the bottom of the HP Chromebook 11-v011dx.
Lift up the black rubber cap until it is completely removed.
Repeat this until all four of the black rubber caps are removed.
Remove three of the 1.3mm screws that keep the battery in place with a Phillips #0 screwdriver.
Use a Phillips #0 screwdriver to remove the 1.3 mm screw that holds the wireless card.
Use a Phillips #0 screwdriver to remove the one 1.3mm screw that connects the speakers and the motherboard together.
