メインコンテンツにスキップ
HP Chromebook 11-v011dx Motherboard Replacement
必要な工具と部品
  1. HP Chromebook 11-v011dx Motherboard  Replacement, Key Board: 手順 1、 3の画像 1 HP Chromebook 11-v011dx Motherboard  Replacement, Key Board: 手順 1、 3の画像 2 HP Chromebook 11-v011dx Motherboard  Replacement, Key Board: 手順 1、 3の画像 3
    • Wedge the spudger between one of the black rubber caps on each of the four corners on the bottom of the HP Chromebook 11-v011dx.
    • Lift up the black rubber cap until it is completely removed.
    • Repeat this until all four of the black rubber caps are removed.
  2. HP Chromebook 11-v011dx Motherboard  Replacement: 手順 2、 2の画像 1 HP Chromebook 11-v011dx Motherboard  Replacement: 手順 2、 2の画像 2
    • Locate the two smaller black rubber caps on the top corners of the HP ChromeBook 11-v011dx. Wedge the spudger between one of them.
    • Lift up the small black rubber cap until it is completely off.
    • Repeat this step one more time to remove the other small black rubber cap on the other side.
  3. HP Chromebook 11-v011dx Motherboard  Replacement: 手順 3、 2の画像 1 HP Chromebook 11-v011dx Motherboard  Replacement: 手順 3、 2の画像 2
    • Locate the eleven screws on the bottom the HP ChromeBook. Six are located under the larger black rubber caps and the others are in different locations.
    • Use a Phillips #0 screwdriver to remove eleven 1.3mm screws.
  4. HP Chromebook 11-v011dx Motherboard  Replacement: 手順 4、 3の画像 1 HP Chromebook 11-v011dx Motherboard  Replacement: 手順 4、 3の画像 2 HP Chromebook 11-v011dx Motherboard  Replacement: 手順 4、 3の画像 3
    • Make sure to do steps 1-3 or it will be impossible to lift up the key board and you may also do damage to the hardware.
    • Wedge the spudger between the key board and the bottom panel, carefully go around the keyboards edges gently.
    • Lift the spudger a little in the front of the keyboard until the key board lifts up.
    • With your hands, slowly and carefully lift the key board up.
  5. HP Chromebook 11-v011dx Motherboard  Replacement: 手順 5、 1の画像 1
    • Locate the black tab that holds a wire in place that keeps the keyboard connected to the mother board.
    • Slowly unplug this wire that connects to the key board.
  6. HP Chromebook 11-v011dx Motherboard  Replacement, Battery: 手順 6、 2の画像 1 HP Chromebook 11-v011dx Motherboard  Replacement, Battery: 手順 6、 2の画像 2
    • Remove three of the 1.3mm screws that keep the battery in place with a Phillips #0 screwdriver.
  7. HP Chromebook 11-v011dx Motherboard  Replacement: 手順 7、 1の画像 1
    • Make sure to hold the white tab portion of the plug and not the wire itself. If you unplug it by holding the wires, you may rip out the wires.
    • Slowly unplug the wire that connects the battery to the motherboard with your hands.
  8. HP Chromebook 11-v011dx Motherboard  Replacement: 手順 8、 1の画像 1
    • There is a thick black wire strip that is going across the battery for a different part of the HP ChromeBook 11-v011dx. Be mindful when removing the motherboard so you do not damage this strip.
    • Remove the battery carefully using your hands.
  9. HP Chromebook 11-v011dx Motherboard  Replacement, Screen: 手順 9、 2の画像 1 HP Chromebook 11-v011dx Motherboard  Replacement, Screen: 手順 9、 2の画像 2
    • Use a Phillips #0 screwdriver to remove the 1.3 mm screw that holds the wireless card.
  10. HP Chromebook 11-v011dx Motherboard  Replacement: 手順 10、 2の画像 1 HP Chromebook 11-v011dx Motherboard  Replacement: 手順 10、 2の画像 2
    • Remove the wireless card from the motherboard with your own hand.
  11. HP Chromebook 11-v011dx Motherboard  Replacement: 手順 11、 2の画像 1 HP Chromebook 11-v011dx Motherboard  Replacement: 手順 11、 2の画像 2
    • Find the wire that connects the screen to the motherboard.
    • Lift black tab that holds the wire in place.
    • Remove the wire.
  12. HP Chromebook 11-v011dx Motherboard  Replacement: 手順 12、 2の画像 1 HP Chromebook 11-v011dx Motherboard  Replacement: 手順 12、 2の画像 2
    • Find the display cable that connects the screen to the motherboard.
    • Lift black tab that holds the display cable in place.
    • Remove display cable.
  13. HP Chromebook 11-v011dx Motherboard  Replacement: 手順 13、 3の画像 1 HP Chromebook 11-v011dx Motherboard  Replacement: 手順 13、 3の画像 2 HP Chromebook 11-v011dx Motherboard  Replacement: 手順 13、 3の画像 3
    • Use a Phillips #0 screwdriver to remove the four 1.3mm screws that hold the screen in place.
    • Two screws are on the left of the laptop and two are on the right of the laptop.
  14. HP Chromebook 11-v011dx Motherboard  Replacement: 手順 14、 2の画像 1 HP Chromebook 11-v011dx Motherboard  Replacement: 手順 14、 2の画像 2
    • Be careful when removing the screen so it doesn't get caught on any wires.
    • Remove the screen from the laptop.
  15. HP Chromebook 11-v011dx Motherboard  Replacement, Speaker: 手順 15、 2の画像 1 HP Chromebook 11-v011dx Motherboard  Replacement, Speaker: 手順 15、 2の画像 2
    • Use a Phillips #0 screwdriver to remove the one 1.3mm screw that connects the speakers and the motherboard together.
  16. HP Chromebook 11-v011dx Motherboard  Replacement: 手順 16、 1の画像 1
    • Make sure to hold the white part of the plug and not the wire. If unplugged by holding the wires, it can rip out wires.
    • Slowly and cautiously unplug the wire that connects the speakers to the motherboard with your hands.
  17. HP Chromebook 11-v011dx Motherboard  Replacement: 手順 17、 2の画像 1 HP Chromebook 11-v011dx Motherboard  Replacement: 手順 17、 2の画像 2
    • Be careful with the wire between both end of the speakers. It's between metal parts and can get caught.
    • Slowly remove both ends of the speakers with your hands.
  18. HP Chromebook 11-v011dx Motherboard  Replacement, Motherboard: 手順 18、 2の画像 1 HP Chromebook 11-v011dx Motherboard  Replacement, Motherboard: 手順 18、 2の画像 2
    • Please hold the white tab and not the wires or it may rip the wires out.
    • Remove these wires that connect the motherboard to the power port.
  19. HP Chromebook 11-v011dx Motherboard  Replacement: 手順 19、 2の画像 1 HP Chromebook 11-v011dx Motherboard  Replacement: 手順 19、 2の画像 2
    • Locate the wire at the top of the motherboard.
    • Lift up the black tab that holds the wire in place.
    • Remove the wire.
  20. HP Chromebook 11-v011dx Motherboard  Replacement: 手順 20、 2の画像 1 HP Chromebook 11-v011dx Motherboard  Replacement: 手順 20、 2の画像 2
    • Locate the wire that connects the USB port and the motherboard.
    • Lift up the black tap that holds the wire in place.
    • Remove the wire.
  21. HP Chromebook 11-v011dx Motherboard  Replacement: 手順 21、 3の画像 1 HP Chromebook 11-v011dx Motherboard  Replacement: 手順 21、 3の画像 2 HP Chromebook 11-v011dx Motherboard  Replacement: 手順 21、 3の画像 3
    • Use a Phillips #0 screwdriver to remove five 1.3mm screws that hold the motherboard in place.
  22. HP Chromebook 11-v011dx Motherboard  Replacement: 手順 22、 2の画像 1 HP Chromebook 11-v011dx Motherboard  Replacement: 手順 22、 2の画像 2
    • Remove the motherboard by hand.
終わりに
作成者
2人の作成者と共同で作成されました。
Kyle DeMello
メンバー登録日: 10/20/17
542 ポイント
5のガイドは作成済み
チーム
UMass Dartmouth, Team S4-G2, Julie Fall 2017 UMass Dartmouth, Team S4-G2, Julie Fall 2017人のメンバー
UMASSD-JULIE-F17S4G2
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 275
