はじめに
This guide will walk you through easy steps in order to change the keyboard for your HP Chromebook 11-v002dx.
You may want to try cleaning the area underneath your keys and keyboard before replacing your board entirely, as dust can occasionally accumulate and prevent the keyboard from functioning.
必要な工具と部品
Place your laptop bottom up on your work space.
Use a Phillips #0 screwdriver to remove the eleven 0.2 mm screws, including the six from underneath the adhesives.
ある他の人がこのガイドを完成しました。
