メインコンテンツにスキップ
HP Chromebook 11-2210nr LCD Screen Replacement
必要な工具と部品
  1. HP Chromebook 11-2210nr LCD Screen Replacement, LCD Screen: 手順 1、 1の画像 1
    この手順で使用する道具:
    購入する
    • Remove adhesive tabs using fine point tweezers or a metal spudger.
    • These adhesives are typically located at the bottom left and right corners of the screen.
  2. HP Chromebook 11-2210nr LCD Screen Replacement: 手順 2、 1の画像 1
    • Remove the one 3 mm screw located underneath both adhesive layers using a Phillips #0 screwdriver.
  3. HP Chromebook 11-2210nr LCD Screen Replacement: 手順 3、 2の画像 1 HP Chromebook 11-2210nr LCD Screen Replacement: 手順 3、 2の画像 2
    • Using a metal spudger, gently pry the front plastic frame (or bezel) off of the device by inserting the tool along the inside edge of the bezel.
    • Completely open the screen as far as possible to remove the bottom edge of the bezel from the laptop.
    • Be sure to disconnect the bezel from all the way around the screen before completely removing.
  4. HP Chromebook 11-2210nr LCD Screen Replacement: 手順 4、 2の画像 1 HP Chromebook 11-2210nr LCD Screen Replacement: 手順 4、 2の画像 2
    • Remove the four black 3 mm screws along the left and right sides of the LCD screen using a Phillips #0 screwdriver.
  5. HP Chromebook 11-2210nr LCD Screen Replacement: 手順 5、 1の画像 1
    • After removing all screws, gently lower the LCD screen onto the keyboard.
    • The LCD screen will not be completely disconnected from the laptop just yet.
  6. HP Chromebook 11-2210nr LCD Screen Replacement: 手順 6、 2の画像 1 HP Chromebook 11-2210nr LCD Screen Replacement: 手順 6、 2の画像 2
    • Gently use the spudger to pry off the tape on top of the gold chip. You may also use your hands to gently remove the tape.
  7. HP Chromebook 11-2210nr LCD Screen Replacement: 手順 7、 2の画像 1 HP Chromebook 11-2210nr LCD Screen Replacement: 手順 7、 2の画像 2
    • Remove the display cable by gently sliding out the cable away from the LCD screen.
    • This action disconnects the LCD screen from the rest of the device, allowing it to be completely removed.
終わりに
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Kimberly Rodriguez
メンバー登録日: 10/02/18
425 ポイント
2のガイドは作成済み
チーム
Sam Houston State, Team S11-G3, Blackburne Fall 2018 Sam Houston State, Team S11-G3, Blackburne Fall 2018人のメンバー
SHSU-BLACKBURNE-F18S11G3
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 11
今までの合計 346
