はじめに
The motherboard is the primary piece of circuitry that helps keep your laptop running. After troubleshooting through the possible issues with the motherboard and determining that it needs a replacement, you can follow these steps in order to accomplish that goal. This guide will walk you through the steps of replacing the motherboard in your HP Chromebook 11 G8 EE.
Note that there are many symptoms to a failing motherboard such as a loose connection that is a lot less costly than a replacement.
必要な工具と部品
Use a Phillips #1 screwdriver to remove:
Four 7 mm screws.
Two 8 mm screws.
Peel back the film over the speaker's motherboard connector.
Disconnect the speaker cable from the connector on the motherboard.
Disconnect the battery cable from the motherboard by pulling the connector straight out of its motherboard port.
Unscrew the single screw securing the Wi-Fi card/cover using a Phillips #1 screwdriver.
Remove wireless antenna cables from the module using tweezers.
Pull the Wi-Fi card out from its motherboard port using tweezers.
