はじめに
This is a replacement guide for the HP Chromebook 11 G5 battery. The main purpose of the steps below is to show you how to replace the internal battery. If these steps are followed carefully and correctly the battery should be replaced easily.
必要な工具と部品
Remove four large rubber pads from the bottom of the device to reveal screws using the pointed end of a spudger.
Remove the two wires from the top of the WLAN module by pulling them gently with a spudger or your hand and snapping the wires out of place.
4 の人々がこのガイドを完成させました。
