メインコンテンツにスキップ
HP Chromebook 11 G4 SD Card Reader Replacement
必要な工具と部品
  1. HP Chromebook 11 G4 SD Card Reader Replacement, Keyboard: 手順 1、 1の画像 1
    • Position the closed Chromebook with the rubber pads are facing up.
  2. HP Chromebook 11 G4 SD Card Reader Replacement: 手順 2、 2の画像 1 HP Chromebook 11 G4 SD Card Reader Replacement: 手順 2、 2の画像 2
    • Slide the flat end of the spudger under the rubber pads at the upper right-hand and the upper left-hand corners.
    • Pry off the rubber pads to reveal a screw under each pad.
    • The rubber pads are attached with a strong adhesive. The force applied may damage the pads.
  3. HP Chromebook 11 G4 SD Card Reader Replacement: 手順 3、 2の画像 1 HP Chromebook 11 G4 SD Card Reader Replacement: 手順 3、 2の画像 2
    • Remove the eleven 6mm Phillips #1 screws.
  4. HP Chromebook 11 G4 SD Card Reader Replacement: 手順 4、 1の画像 1
    • Flip over the Chromebook and open it.
  5. HP Chromebook 11 G4 SD Card Reader Replacement: 手順 5、 2の画像 1 HP Chromebook 11 G4 SD Card Reader Replacement: 手順 5、 2の画像 2
    • Insert the flat end of the spudger between the bottom body of the Chromebook and keyboard body.
    • Slide the spudger along the gap, applying downward pressure to separate the two components.
    • You should hear popping sounds as you slide the spudger along the edge.
    • If the spudger gets stuck while sliding, simply slide the spudger back for a bit, and continue sliding forward.
  6. HP Chromebook 11 G4 SD Card Reader Replacement: 手順 6、 1の画像 1
    • Lift the bottom of the keyboard assembly to reveal the internal components of the device.
  7. HP Chromebook 11 G4 SD Card Reader Replacement: 手順 7、 3の画像 1 HP Chromebook 11 G4 SD Card Reader Replacement: 手順 7、 3の画像 2 HP Chromebook 11 G4 SD Card Reader Replacement: 手順 7、 3の画像 3
    • Use the pointed end of the spudger to flip up the black tabs on the two ZIF connectors located on the motherboard.
    • Disconnect the ribbon cables from the motherboard by gently sliding them out of their sockets.
  8. HP Chromebook 11 G4 SD Card Reader Replacement: 手順 8、 1の画像 1
    • Remove the keyboard assembly by lifting it off the laptop base.
  9. HP Chromebook 11 G4 SD Card Reader Replacement, SD Card Reader: 手順 9、 3の画像 1 HP Chromebook 11 G4 SD Card Reader Replacement, SD Card Reader: 手順 9、 3の画像 2 HP Chromebook 11 G4 SD Card Reader Replacement, SD Card Reader: 手順 9、 3の画像 3
    • Flip up the flap on the ZIP connector with your finger.
    • Gently pull out the ribbon cable.
  10. HP Chromebook 11 G4 SD Card Reader Replacement: 手順 10、 2の画像 1 HP Chromebook 11 G4 SD Card Reader Replacement: 手順 10、 2の画像 2
    • Remove the two 4 mm Phillips #1 screws.
  11. HP Chromebook 11 G4 SD Card Reader Replacement: 手順 11、 2の画像 1 HP Chromebook 11 G4 SD Card Reader Replacement: 手順 11、 2の画像 2
    • Lift the ribbon cable back and out of the way.
    • Pull out the SD card reader.
終わりに
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Jair Herrera
メンバー登録日: 04/26/17
694 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team S16-G5, Banghart Winter 2018 Cal Poly, Team S16-G5, Banghart Winter 2018人のメンバー
CPSU-BANGHART-W18S16G5
5 メンバー
15のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 16
今までの合計 1,083
