メインコンテンツにスキップ
HP Chromebook 11 G4 LCD Replacement
必要な工具と部品
  1. HP Chromebook 11 G4 LCD Replacement, LCD: 手順 1、 3の画像 1 HP Chromebook 11 G4 LCD Replacement, LCD: 手順 1、 3の画像 2 HP Chromebook 11 G4 LCD Replacement, LCD: 手順 1、 3の画像 3
    • Open the laptop.
    • With the plastic spudger or your fingers, gently peel off the two thin adhesive layers at the left and right bottom edges of the screen.
    • Do not pry up the plastic bezel (monitor frame), just the adhesive layer.
    • If the adhesive layer isn't coming off, use a metal spudger.
  2. HP Chromebook 11 G4 LCD Replacement: 手順 2、 2の画像 1 HP Chromebook 11 G4 LCD Replacement: 手順 2、 2の画像 2
    • Remove the two 3 mm Phillips #00 screws located underneath the adhesive layers that were removed in the previous step
  3. HP Chromebook 11 G4 LCD Replacement: 手順 3、 3の画像 1 HP Chromebook 11 G4 LCD Replacement: 手順 3、 3の画像 2 HP Chromebook 11 G4 LCD Replacement: 手順 3、 3の画像 3
    • Gently pry up the plastic bezel with the small, narrow end of the metal spudger.
    • Insert the long, flat end of the metal spudger into the gap.
    • Slide the metal spudger along the edge to disconnect the bezel from the laptop
    • You should hear popping sounds as you slide the spudger along the edge.
    • If the spudger gets stuck while sliding, it's okay to use more force.
  4. HP Chromebook 11 G4 LCD Replacement: 手順 4、 2の画像 1 HP Chromebook 11 G4 LCD Replacement: 手順 4、 2の画像 2
    • Tilt the laptop screen as far back as possible
    • Hold the bezel with both hands, then pull the bezel towards you to disconnect the bottom edge of the bezel from the laptop.
    • You may have to use extra force for this step
  5. HP Chromebook 11 G4 LCD Replacement: 手順 5、 3の画像 1 HP Chromebook 11 G4 LCD Replacement: 手順 5、 3の画像 2 HP Chromebook 11 G4 LCD Replacement: 手順 5、 3の画像 3
    • Remove the four silver 4 mm Phillips #0 screws at the bottom of the LCD.
    • Remove the four black 3 mm Phillips #00 screws along the perimeter of the LCD.
  6. HP Chromebook 11 G4 LCD Replacement: 手順 6、 2の画像 1 HP Chromebook 11 G4 LCD Replacement: 手順 6、 2の画像 2
    • Lift the LCD off its mount and gently lay it facedown on the keyboard.
  7. HP Chromebook 11 G4 LCD Replacement: 手順 7、 3の画像 1 HP Chromebook 11 G4 LCD Replacement: 手順 7、 3の画像 2 HP Chromebook 11 G4 LCD Replacement: 手順 7、 3の画像 3
    • Peel off the clear sticker covering the display cable at the base of the LCD.
    • Gently pull the display cable from the connector.
終わりに
13 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Jonah Silva
メンバー登録日: 04/26/17
785 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team S23-G5, Livingston Spring 2017 Cal Poly, Team S23-G5, Livingston Spring 2017人のメンバー
CPSU-LIVINGSTON-S17S23G5
3 メンバー
6のガイドは作成済み
3 件のコメント
Thanks for the great guidance. Easy as pie!
lcowsert - 返信
i need to replace the top cover of this Laptop HP Chromebook 11-2201NA Can you help
grahamcoles - 返信
I did it! Thank you for terrific instructions.
Krenee - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 29
今までの合計 7,590
