メインコンテンツにスキップ
HP Chromebook 11 G3 Display Assembly Replacement
必要な工具と部品
  1. HP Chromebook 11 G3 Display Assembly Replacement, Keyboard Mount: 手順 1、 2の画像 1 HP Chromebook 11 G3 Display Assembly Replacement, Keyboard Mount: 手順 1、 2の画像 2
    • Flip the laptop upside down so that the lid lies flat on the table.
    • Remove the nine 6mm Phillips #00 screws that line the border.
  2. HP Chromebook 11 G3 Display Assembly Replacement: 手順 2、 2の画像 1 HP Chromebook 11 G3 Display Assembly Replacement: 手順 2、 2の画像 2
    この手順で使用する道具:
    購入する
    • Remove the two rubber feet closest to the hinge using tweezers.
    • Remove the two 6mm Phillips #00 screws revealed under these rubber feet.
    • The rubber feet may tear while removal; preventing this can be difficult, but it won’t harm the laptop. If desired, replace these rubber feet during reassembly.
  3. HP Chromebook 11 G3 Display Assembly Replacement: 手順 3、 1の画像 1
    • Flip the laptop so it is in the upright position.
    • Open the lid.
    • Unsnap the keyboard mount along the border of the laptop using a plastic opening tool.
    • This may require more force than expected. Hearing loud clicks as the plastic opening tool slides along the seam is normal.
  4. HP Chromebook 11 G3 Display Assembly Replacement: 手順 4、 3の画像 1 HP Chromebook 11 G3 Display Assembly Replacement: 手順 4、 3の画像 2 HP Chromebook 11 G3 Display Assembly Replacement: 手順 4、 3の画像 3
    • Tilt the keyboard mount up.
    • Use a spudger to flip up the two ZIF connector retaining flaps for the ribbon cables that connect the keyboard mount to the motherboard.
    • Gently remove both ribbon cables.
  5. HP Chromebook 11 G3 Display Assembly Replacement: 手順 5、 1の画像 1
    • Lift the keyboard mount out of the laptop.
  6. HP Chromebook 11 G3 Display Assembly Replacement, Display Assembly: 手順 6、 1の画像 1
    • Gently tug on the black and white wires connected to the Wi-Fi module to disconnect them.
  7. HP Chromebook 11 G3 Display Assembly Replacement: 手順 7、 2の画像 1 HP Chromebook 11 G3 Display Assembly Replacement: 手順 7、 2の画像 2
    • Using a spudger, lift the ZIF retaining flap that secures the display’s ribbon cable to the motherboard.
    • Gently pull the ribbon cable out of its socket.
  8. HP Chromebook 11 G3 Display Assembly Replacement: 手順 8、 1の画像 1
    • Free the wire from the casing.
  9. HP Chromebook 11 G3 Display Assembly Replacement: 手順 9、 1の画像 1
    • Remove the two 6mm Phillips #00 screws located near the upper left and right corners of the hinge mounts.
    • Hold the lid so that it is folded slightly inwards while removing the screws so that the lid doesn’t fall.
  10. HP Chromebook 11 G3 Display Assembly Replacement: 手順 10、 1の画像 1
    • Rotate the lid to a 90-degree angle with the table.
    • Shimmy the lid out of the laptop.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Rahul Goyal
メンバー登録日: 04/26/17
1,369 ポイント
10のガイドは作成済み
チーム
Cal Poly, Team S23-G3, Livingston Spring 2017 Cal Poly, Team S23-G3, Livingston Spring 2017人のメンバー
CPSU-LIVINGSTON-S17S23G3
4 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 17
今までの合計 1,512
