メインコンテンツにスキップ
HP Chromebook 11 G3 Charging Port Replacement
必要な工具と部品
  1. HP Chromebook 11 G3 Charging Port Replacement, Keyboard Mount: 手順 1、 2の画像 1 HP Chromebook 11 G3 Charging Port Replacement, Keyboard Mount: 手順 1、 2の画像 2
    • Flip the laptop upside down so that the lid lies flat on the table.
    • Remove the nine 6mm Phillips #00 screws that line the border.
  2. HP Chromebook 11 G3 Charging Port Replacement: 手順 2、 2の画像 1 HP Chromebook 11 G3 Charging Port Replacement: 手順 2、 2の画像 2
    この手順で使用する道具:
    購入する
    • Remove the two rubber feet closest to the hinge using tweezers.
    • Remove the two 6mm Phillips #00 screws revealed under these rubber feet.
    • The rubber feet may tear while removal; preventing this can be difficult, but it won’t harm the laptop. If desired, replace these rubber feet during reassembly.
  3. HP Chromebook 11 G3 Charging Port Replacement: 手順 3、 1の画像 1
    • Flip the laptop so it is in the upright position.
    • Open the lid.
    • Unsnap the keyboard mount along the border of the laptop using a plastic opening tool.
    • This may require more force than expected. Hearing loud clicks as the plastic opening tool slides along the seam is normal.
  4. HP Chromebook 11 G3 Charging Port Replacement: 手順 4、 3の画像 1 HP Chromebook 11 G3 Charging Port Replacement: 手順 4、 3の画像 2 HP Chromebook 11 G3 Charging Port Replacement: 手順 4、 3の画像 3
    • Tilt the keyboard mount up.
    • Use a spudger to flip up the two ZIF connector retaining flaps for the ribbon cables that connect the keyboard mount to the motherboard.
    • Gently remove both ribbon cables.
  5. HP Chromebook 11 G3 Charging Port Replacement: 手順 5、 1の画像 1
    • Lift the keyboard mount out of the laptop.
  6. HP Chromebook 11 G3 Charging Port Replacement, Charging Port: 手順 6、 1の画像 1
    • Gently remove the charging port’s slide-out connector from the motherboard.
  7. HP Chromebook 11 G3 Charging Port Replacement: 手順 7、 1の画像 1
    • Locate the two brown clips that secure the charging port to the motherboard from both edges.
    • Remove the charging port by sliding the plastic opening tool between the charging port and one of the clips, and then prying.
  8. HP Chromebook 11 G3 Charging Port Replacement: 手順 8、 1の画像 1
    • Lift the charging port out of the base.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Rahul Goyal
メンバー登録日: 04/26/17
1,369 ポイント
10のガイドは作成済み
チーム
Cal Poly, Team S23-G3, Livingston Spring 2017 Cal Poly, Team S23-G3, Livingston Spring 2017人のメンバー
CPSU-LIVINGSTON-S17S23G3
4 メンバー
12のガイドは作成済み
コメント 1 件
I have a Model CB2 (also known as 11-1102) that has this same issue. Would the instructions be the same? Would the part be the same? Where did you purchase a replacement charging port?
Jim Grybowski - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 20
今までの合計 2,158
