はじめに
This guide describes how to replace a faulty motherboard in an HP Chromebook 14-x013dx. A malfunctioning motherboard could be due to overheating or other damage to the laptop. This replacement involves removing the laptop’s keyboard, and the total repair time should take about 25 minutes.
必要な工具と部品
Using the plastic spudger, gently lift the 5 rubber pads away from their seating.
Remove the eight 4mm screws holding the battery in place using the Phillips #00 screwdriver.
ある他の人がこのガイドを完成しました。
