はじめに
This guide demonstrates the replacement of the Chromebook's battery. This will require the removal of the front keyboard plate and accessing the laptop's internals. You will need to keep track of up to 20 removed screws in total.
必要な工具と部品
Using the plastic spudger, gently lift the 5 rubber pads away from their seating.
Remove the eight 4mm screws holding the battery in place using the Phillips #00 screwdriver.
3 の人々がこのガイドを完成させました。
