はじめに
If you find yourself needing to replace the motherboard for your HP Beats Special Edition 15-p390nr, this guide will help you do so.
必要な工具と部品
Turn computer over and begin removing noticeable 8mm screws with a Phillips #0 screwdriver.
Remove the rubberized feet located on the left and right shoulder of the computer to uncover hidden 8mm screws.
The shoulder caps are removable. Underneath there are 2 additional screws.
Both sholders of the computer need to be popped off.
Underneath are 2 additional screws.
The guide does not mention this, so it is easy to miss
Unclip wires connected to the motherboard and remove keyboard from the device.
This is a short replacement how do you replace just the keyboard not the whole top part with keyboard if you gonna replace a keyboard replaced just to keyboard not all the other parts in the top 2
Yes I’m wondering the same thing. I see just the keyboard for sale online, but it appears it may have plastic rivets that connect it to the top panel. Can anyone confirm this to be the case, that the keyboard itself can be removed from the top panel? Is the keyboard held to the top panel assembly by screws or by rivets?
Wow im wandering the same thing. I bought a keyboard replacement online but its just the keyboard. How the heck are we supposed to change just that.
Bros, I just cracked the code…! You have to pry the thin metal frame off using a small picking tool or even a butter knife.
Slide in your knife or pick and pull up a tad; the melted plastic points with slip back or crack away just enough to pull the frame off. Then you can pull out that old keyboard an slide in your replacement.
:) #ResearchFlatEarth
ある他の人がこのガイドを完成しました。
4 件のコメント
What does it mean if it beeps twice and doesn’t turn on? I replaced the cmos battery and thought that would fix that beeping sound.
You may want yo start with reseating your ram or replacing it
