メインコンテンツにスキップ
HP Beats Special Edition 15-p390nr Motherboard Replacement
必要な工具と部品
  1. HP Beats Special Edition 15-p390nr Motherboard Replacement, Keyboard: 手順 1、 2の画像 1 HP Beats Special Edition 15-p390nr Motherboard Replacement, Keyboard: 手順 1、 2の画像 2
    • Turn computer off before starting.
    • Turn computer over and begin removing noticeable 8mm screws with a Phillips #0 screwdriver.
  2. HP Beats Special Edition 15-p390nr Motherboard Replacement: 手順 2、 2の画像 1 HP Beats Special Edition 15-p390nr Motherboard Replacement: 手順 2、 2の画像 2
    • Some screws may be hidden under a screw cover.
    • Simply use a metal spudger to pop off the screw cover to unveil the hidden 8mm screw.
    • Screw cover may fly when removing.
  3. HP Beats Special Edition 15-p390nr Motherboard Replacement: 手順 3、 2の画像 1 HP Beats Special Edition 15-p390nr Motherboard Replacement: 手順 3、 2の画像 2
    • Once screws are removed you may now remove the optical drive.
    • Remove the hidden 3mm screw in the optical drive port.
  4. HP Beats Special Edition 15-p390nr Motherboard Replacement: 手順 4、 2の画像 1 HP Beats Special Edition 15-p390nr Motherboard Replacement: 手順 4、 2の画像 2
    • Remove the rubberized feet located on the left and right shoulder of the computer to uncover hidden 8mm screws.
    • Popping noises are normal.
    • The shoulder caps are removable. Underneath there are 2 additional screws.
  5. HP Beats Special Edition 15-p390nr Motherboard Replacement: 手順 5、 2の画像 1 HP Beats Special Edition 15-p390nr Motherboard Replacement: 手順 5、 2の画像 2
    • Flip computer over and wedge metal spudger along the computer to pop off keyboard panel
  6. HP Beats Special Edition 15-p390nr Motherboard Replacement: 手順 6、 2の画像 1 HP Beats Special Edition 15-p390nr Motherboard Replacement: 手順 6、 2の画像 2
    • Unclip wires connected to the motherboard and remove keyboard from the device.
    • 17 screws should be removed up to this point.
  7. HP Beats Special Edition 15-p390nr Motherboard Replacement, Motherboard: 手順 7、 1の画像 1
    • Remove screws from the motherboard.
    • 11 screws should be removed from the motherboard
  8. HP Beats Special Edition 15-p390nr Motherboard Replacement: 手順 8、 1の画像 1
    • Unclamp wire strips from motherboard.
  9. HP Beats Special Edition 15-p390nr Motherboard Replacement: 手順 9、 1の画像 1
    • Detach by lifting the motherboard up and flip the motherboard over.
  10. HP Beats Special Edition 15-p390nr Motherboard Replacement: 手順 10、 1の画像 1
    • Unclip wifi card for further procedures
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Michelle
メンバー登録日: 10/02/18
115 ポイント
1ガイドが承認済み
チーム
Linn Benton Community College, Team S1-G3, Karnes Fall 2018 Linn Benton Community College, Team S1-G3, Karnes Fall 2018人のメンバー
LBCC-KARNES-F18S1G3
4 メンバー
7のガイドは作成済み
4 件のコメント
Please where can i buy the motherboard ?
Nelson - 返信
Please, where can i buy a new motherboard for this laptop ? Thank you
Nelson - 返信
What does it mean if it beeps twice and doesn’t turn on? I replaced the cmos battery and thought that would fix that beeping sound.
Landon Elliott - 返信
You may want yo start with reseating your ram or replacing it
Juan Lopez -
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 38
今までの合計 2,678
