はじめに
This guide is helpful if you need to replace a dead or damaged battery. Be careful when removing the battery to not bend or puncture it because it may contain hazardous chemicals.
必要な工具と部品
Using a spudger or your fingers, disconnect the power cable by sliding the connector out of the socket on the motherboard.
この手順で使用する道具:Plastic Cards$2.99
Using a plastic card or a nylon spudger, carefully pry the battery from the adhesive on the tablet.
もう少しです!
終わりに
