はじめに
If the device's speaker isn't working, then it may be necessary to replace it. The most challenging step to replace the speaker is removing the back cover. The tools listed (or similar) are necessary to fix the speaker properly.
必要な工具と部品
Use the Torx T5 screwdriver and remove the 3mm screws on all four corners of the device.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
