はじめに
This guide will show you how to remove and replace the cameras on your HP 7 Plus 1301. This will include opening the back cover of your tablet, disconnecting both cameras and removing them. This guide will show you a detailed step by step process even if you have no experience in tablets and electronics. Please click on the links below to purchase the necessary tools needed for this project.
必要な工具と部品
Using a Torx T5 screwdriver, remove the 3mm screws on all four corners of the device.
ある他の人がこのガイドを完成しました。
